Datasheet ADA4856-3 (Analog Devices) - 2
DescriptionSingle-Supply, High Speed, Fixed G = +2, Rail-to-Rail Output Video Amplifier
Pages / Page21 / 2 — ADA4856-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 565 Kb
ADA4856-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Tutorials
ADA4856-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Tutorials
View a parametric search of comparable parts.
Tutorials
• MT-032: Ideal Voltage Feedback (VFB) Op Amp
EVALUATION KITS
• MT-033: Voltage Feedback Op Amp Gain and Bandwidth • ADA4856-3 Evaluation Board • MT-047: Op Amp Noise • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
DOCUMENTATION
Noise, and Equivalent Noise Bandwidth
Application Notes
• MT-049: Op Amp Total Output Noise Calculations for • AN-402: Replacing Output Clamping Op Amps with Input Single-Pole System Clamping Amps • MT-050: Op Amp Total Output Noise Calculations for • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease Second-Order System Design Constraints in Low Voltage High Speed Systems • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-581: Biasing and Decoupling Op Amps in Single • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, Supply Applications SFDR, MTPR
Data Sheet
• MT-056: High Speed Voltage Feedback Op Amps • ADA4856-3: High Speed, Single-Supply, Fixed G = +2, Rail- • MT-058: Effects of Feedback Capacitance on VFB and CFB to-Rail Output Video Amplifier Data Sheet Op Amps
User Guides
• MT-059: Compensating for the Effects of Input • UG-115: Universal Evaluation Board for Triple, High Speed Capacitance on VFB and CFB Op Amps Used in Current-to- Op Amps Offered in 16-Lead, 4 mm × 4 mm LFCSP Voltage Converters Packages • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps
TOOLS AND SIMULATIONS DESIGN RESOURCES
• Power Dissipation vs Die Temp • VRMS/dBm/dBu/dBV calculators • ADA4856-3 Material Declaration • PCN-PDN Information • Quality And Reliability • Symbols and Footprints
DISCUSSIONS
View all ADA4856-3 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Applications Connection Diagram General Description Revision History Specifications 5 V Operation 3.3 V Operation Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Using the ADA4856-3 in Gains Equal to +1, −1 Unity-Gain Operation Option 1 Option 2 Inverting Unity-Gain Operation Using the ADA4856-3 in Gains Equal to +3, +4, and +5 Gain of +3 Configuration Gain of +4 Configuration Gain of +5 Configuration 20 MHz Active Low-Pass Filter Video Line Driver Single-Supply Operation Power Down Layout Considerations Power Supply Bypassing Outline Dimensions Ordering Guide
