Single-Supply, High Speed, Fixed G = +2, Rail-to-Rail Output Video Amplifier
Pages / Page
21 /10 — Data Sheet. ADA4856-3. 100. H /√. Hz /√A. E (nV. OIS. T N E R. VOLTA. …
Revision
B
PDF / 565 Kb
Data Sheet. ADA4856-3. 100. H /√. Hz /√A. E (nV. OIS. T N E R. VOLTA. CUR. 10k. 100k. FREQUENCY (Hz). 0.06. 1.5. VS = 5V. VS = 3.3V. 0.04. 1.0. 0.02. 0.5. OLTA
Data SheetADA4856-31k100z))H /√Hz /√A(pE (nVEOISIS100O10NNGET N E RVOLTACUR101 117 101001k10k100k1M101001k10k100k1M 120 FREQUENCY (Hz) 07686- FREQUENCY (Hz) 07686- Figure 17. Output Voltage Noise vs. Frequency Figure 20. Output Current Noise vs. Frequency 0.061.5VS = 5VVS = 5VVS = 3.3VVS = 3.3V0.041.0))VV(0.02(0.5GEGEOLTA0OLTA0T VT VUUTP –0.02TP –0.5OUOU–0.04–1.0 018 021 –0.06 07686- –1.5 07686- TIME (10ns/DIV)TIME (10ns/DIV) Figure 18. Small Signal Transient Response vs. Supply Voltage Figure 21. Large Signal Transient Response vs. Supply Voltage 0.081.50.061.00.04))VV(CL = 2.2pF(0.5CL = 2.2pF0.02CCGEL = 4.4pFGEL = 4.4pFCL = 6.6pFCL = 6.6pFOLTA00OLTAT VT VUU–0.02TPTP–0.5OUOU–0.04–1.0–0.06 019 022 –0.08 07686- –1.5 07686- TIME (10ns/DIV)TIME (10ns/DIV) Figure 19. Small Signal Transient Response vs. Capacitive Load Figure 22. Large Signal Transient Response vs. Capacitive Load Rev. B | Page 9 of 20 Document Outline Features Applications Connection Diagram General Description Revision History Specifications 5 V Operation 3.3 V Operation Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Using the ADA4856-3 in Gains Equal to +1, −1 Unity-Gain Operation Option 1 Option 2 Inverting Unity-Gain Operation Using the ADA4856-3 in Gains Equal to +3, +4, and +5 Gain of +3 Configuration Gain of +4 Configuration Gain of +5 Configuration 20 MHz Active Low-Pass Filter Video Line Driver Single-Supply Operation Power Down Layout Considerations Power Supply Bypassing Outline Dimensions Ordering Guide
