Datasheet AD8502, AD8504 (Analog Devices) - 6
Description1 µA Micropower CMOS Operational Amplifier
Pages / Page16 / 6 — AD8502/AD8504. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. …
File Format / SizePDF / 525 Kb
AD8502/AD8504. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. Parameter Rating. Table 5. Thermal Characteristics
AD8502/AD8504 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4 Parameter Rating Table 5 Thermal Characteristics
THERMAL RESISTANCE Table 4.
θJA is specified for the worst-case conditions, that is, a device
Parameter Rating
soldered in a circuit board for surface-mount packages. Supply Voltage 6 V
Input Voltage VSS − 0.3 V to VDD + 0.3 V
Package Type θJA θJC Unit
Differential Input Voltage ±6 V 8-Lead SOT-23 (RJ-8) 376 126 °C/W Output Short-Circuit Duration to GND Indefinite 14-Lead TSSOP (RU-14) 180 35 °C/W Storage Temperature Range −65°C to +150°C Operating Temperature Range −40°C to +125°C
ESD CAUTION
Junction Temperature Range −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute maximum ratings apply at 25°C, unless otherwise noted. Rev. A | Page 6 of 16 Document Outline Features Applications Pin Configurations General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Outline Dimensions Ordering Guide
