Datasheet ADA4853-1, ADA4853-2, ADA4853-3 (Analog Devices) - 10
Description | Low Power, Rail-to-Rail Output, Video Op Amps with Ultralow Power |
Pages / Page | 20 / 10 — ADA4853-1/ADA4853-2/ADA4853-3. Data Sheet. –20. 10M. VS = 5V. G = +1. … |
Revision | G |
File Format / Size | PDF / 540 Kb |
ADA4853-1/ADA4853-2/ADA4853-3. Data Sheet. –20. 10M. VS = 5V. G = +1. –30. ADA4853-1/. E (. ADA4853-2. N ( –40. PED 100k. ADA4853-3. JE –50. I T
ADA4853-1/ADA4853-2/ADA4853-3 Data Sheet –20 10M VS = 5V VS = 5V ) G = +1 –30 Ω ) 1M ADA4853-1/ B E ( d C ADA4853-2 N N ( –40 A IO PED 100k CT M ADA4853-3 JE –50 I T RE PU T 10k DE U –60 O O -M P N O 1k O O –70 M -L M CO SED –80 O 100 L
30 0
C
4- 88
–90
05
10 100 1k 10k 100k 1M 10M 100M 100 1k 10k 100k 1M 10M 100M
0 05 4-
FREQUENCY (Hz) FREQUENCY (Hz)
88 05 Figure 19. Common-Mode Rejection vs. Frequency Figure 22. Output Impedance vs. Frequency Disabled
0 –40 VS = 5V G = +2 –10 GAIN = +2 VS = 3V RTO –50 VOUT = 2V p-p B) RL = 150Ω HD2 d –20 c) –PSR B R N ( L = 150Ω HD3 (d –60 IO –30 T N C IO JE –40 RT –70 O RE T Y –50 L +PSR IS RL = 1kΩ HD3 P D –80 P –60 C U NI R O L = 1kΩ HD2 R S –70 M E –90 R W O –80 HA P –100 –90 –100 –110
6 1 01
03
0.1 1 10
4- 4-
FREQUENCY (MHz)
88
FREQUENCY (Hz)
88 05 05 Figure 20. Power Supply Rejection vs. Frequency Figure 23. Harmonic Distortion vs. Frequency
1000 –40 VS = 5V G = +2 ) G = +1 V Ω S = 5V –50 R ( VOUT = 2V p-p L = 150Ω HD3 CE 100 c) B –60 DAN (d E P M 10 ION –70 I T RL = 150Ω HD2 UT P TOR RL = 1kΩ HD3 –80 UT IS D O 1 P IC –90 O N O O L M D- R R –100 L = 1kΩ HD2 E 0.1 S HA O –110 CL
32 0 4- 88
0.01
05
–120
17
100 1k 10k 100k 1M 10M 100M 0.1 1 10
0 4- 88
FREQUENCY (Hz) FREQUENCY (MHz)
05 Figure 21. Output Impedance vs. Frequency Enabled Figure 24. Harmonic Distortion vs. Frequency Rev. G | Page 10 of 20 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS SPECIFICATIONS WITH 3 V SUPPLY SPECIFICATIONS WITH 5 V SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION HEADROOM CONSIDERATIONS OVERLOAD BEHAVIOR AND RECOVERY Input APPLICATIONS INFORMATION SINGLE-SUPPLY VIDEO AMPLIFIER POWER SUPPLY BYPASSING LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
