Datasheet AD8665, AD8666, AD8668 (Analog Devices)
Description | 16 V, 4 MHz Rail-to-Rail Single Op Amp |
Pages / Page | 16 / 1 — 16 V, 4 MHz RR0 Amplifiers. AD8665/. AD8666/. AD8668. FEATURES. PIN … |
Revision | B |
File Format / Size | PDF / 629 Kb |
16 V, 4 MHz RR0 Amplifiers. AD8665/. AD8666/. AD8668. FEATURES. PIN CONFIGURATIONS
link to page 14
16 V, 4 MHz RR0 Amplifiers AD8665/ AD8666/ AD8668 FEATURES PIN CONFIGURATIONS Offset voltage: 2.5 mV max Low input bias current: 1 pA max OUT 1 5 V+ AD8665 Single-supply operation: 5 V to 16 V V– 2 TOP VIEW (Not to Scale) Dual-supply operation: ±2.5 V to ±8 V
039
+IN 3 4 –IN Low noise: 8 nV/√Hz @ 10 kHz
06195-
Wide bandwidth: 4 MHz
Figure 1. AD8665, 5-Lead SOT-23 (RJ-5)
Rail-to-rail output Unity-gain stable NC 1 8 NC Lead-free packaging –IN 2 AD8665 7 VCC AD8666/AD8668 qualified for automotive applications +IN 3 TOP VIEW 6 OUT VEE (Not to Scale) 4 5 NC
040
APPLICATIONS NC = NO CONNECT
06195-
Sensor amplification
Figure 2. AD8665, 8-Lead SOIC_N (R-8)
Reference buffers Medical equipment OUT A 1 8 V+ Physiological measurements –IN A 2 AD8666 7 OUT B Signal filters and conditioning +IN A 3 TOP VIEW 6 –IN B
001
V– (Not to Scale) 4 5 +IN B Consumer audio
06018-
Photodiode amplification
Figure 3. AD8666, 8-Lead SOIC_N (R-8)
ADC driver Level shifting circuits OUT A 1 8 V+ –IN A 2 7 AD8666 OUT B GENERAL DESCRIPTION +IN A 3 TOP VIEW 6 –IN B (Not to Scale)
002 The AD866x family is single supply, rail-to-rail output
V– 4 5 +IN B
06195- amplifiers with low noise performance featuring an extended Figure 4. AD8666, 8-Lead MSOP (RM-8) operating range with supply voltages up to 16 V. They also feature low input bias currents, wide signal bandwidth, and low
1 OUT A 14 OUT D
input voltage and current noise. For lower offset voltage, choose
2 IN A 13 –IN D
the AD8661/AD8662/AD8664 family.
+IN A 3 AD8668 12 +IN D
The combination of low offsets, very low input bias currents,
TOP VIEW V+ 4 11 V– (Not to Scale)
and wide supply range make these amplifiers useful in a wide
+IN B 5 10 +IN C
variety of cost sensitive applications normally associated with
–IN B 6 9 –IN C
much higher priced JFET amplifiers. Systems using high 003
OUT B 7 8 OUT C
06195- impedance sensors, such as photo diodes, benefit from the Figure 5. AD8668, 14-Lead TSSOP (RU-14) combination of low input bias current, low noise, and low offset and bandwidth. The wide operating voltage range matches high
OUT U A 1 14 OUT D
performance ADCs and DACs. Audio applications and medical
–IN A 2 13 –IN D
monitoring equipment can take advantage of the high input
+IN A 3 12 +IN D AD A 864 668
impedance, low voltage and current noise, wide bandwidth, and
V+ 4 TOP VI V E I W E 11 V– (No N t to t Sca S le)
the lack of popcorn noise found in many other low input bias
+IN B 5 10 +IN C 9
current amplifiers.
–IN B 6 –IN C
004
OUT B 7 8 OUT C
The AD866x family is specified over the extended industrial 06195- Figure 6. AD8668, 14-Lead SOIC_N (R-14) temperature range (−40°C to +125°C). See the Ordering Guide for automotive models.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2006–2011 Analog Devices, Inc. All rights reserved.
Document Outline Features Applications General Description Pin Configurations Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Outline Dimensions Ordering Guide
