Datasheet AD8613, AD8617, AD8619 (Analog Devices) - 10
DescriptionLow Cost Micropower, Low Noise CMOS Rail-to-Rail, Input/Output Operational Amplifiers
Pages / Page16 / 10 — AD8613/AD8617/AD8619. Data Sheet. 450. VSY = 1.8V. SY = 1.8V. 400 0V < …
RevisionH
File Format / SizePDF / 291 Kb
AD8613/AD8617/AD8619. Data Sheet. 450. VSY = 1.8V. SY = 1.8V. 400 0V < VCM < 1.8V. TA = 25°C. m (. 350. IL A. IE 300. SY–VOH @ 1mA. 250
AD8613/AD8617/AD8619 Data Sheet 450 VSY = 1.8V SY = 1.8V 400 0V < VCM < 1.8V TA = 25°C m ( 350 IL A IE 300 SY–VOH @ 1mA 250
VSY = 1.8 V or ±0.9 V, unless otherwise noted.
450 80 VSY = 1.8V V ) SY = 1.8V 400 0V < VCM < 1.8V V TA = 25°C m ( 350 IL A 60 RS R IE 300 LY IF P V L P SY–VOH @ 1mA P U 250 AM O S F T 40 200 R O GE BE 150 LTA O VOH @ 1mA NUM V T 20 100 U P T 50
8 25 0
OU
02 2- 2- 62 62
0
5 05
0
0
0 00 00 00 00 00 00 00 –40 –25 –10 5 20 35 50 65 80 95 110 125 1100 100 400 700 –200 –8 –5 –2 10 13 16 19 –1700 –1400 TEMPERATURE (°C) INPUT OFFSET VOLTAGE (µV)
Figure 27. Input Offset Voltage Distribution Figure 30. Output Voltage to Supply Rail vs. Temperature (IL = 1 mA)
2000 100 VSY = 1.8V VSY = 1.8V T TA = 25°C 1500 A = 25°C V) 80 µ 1000 E ( 500 LTAG 60 VO 0 ET S F F –500 CMRR (dB) 40 O PUT –1000 IN 20 –1500
6 -02 622
–2000
05
0
05622-029
–0.5 –0.2 0.1 0.4 0.7 1.0 1.3 1.6 1.9 2.2 100 1k 10k 100k 1M INPUT COMMON-MODE VOLTAGE (V) FREQUENCY (Hz)
Figure 28. Input Offset Voltage vs. Input Common-Mode Voltage Figure 31. CMRR vs. Frequency
1000 120 VSY = 1.8V V ) SY = 1.8V V TA = 25°C TA = 25°C m ( L 100 100 AI VSY–VOH R LY P 80 SOURCE UP 10 S O T 60 E RR (dB) S 1 P LTAG SINK O 40 V VOL UT P 0.1 T 20 U
7
O
-02 622
0.01
05
0
05622-030
0.001 0.01 0.1 1 10 100 1k 10k 1M LOAD CURRENT (mA) FREQUENCY (Hz)
Figure 29. Output Voltage to Supply Rail vs. Load Current Figure 32. PSRR vs. Frequency Rev. H | Page 10 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
