Datasheet AD8613, AD8617, AD8619 (Analog Devices)
Description | Low Cost Micropower, Low Noise CMOS Rail-to-Rail, Input/Output Operational Amplifiers |
Pages / Page | 16 / 1 — Low Cost Micropower, Low Noise CMOS. Rail-to-Rail, Input/Output … |
Revision | H |
File Format / Size | PDF / 291 Kb |
Low Cost Micropower, Low Noise CMOS. Rail-to-Rail, Input/Output Operational Amplifiers. Data Sheet. AD8613/. AD8617/. AD8619
Low Cost Micropower, Low Noise CMOS Rail-to-Rail, Input/Output Operational Amplifiers Data Sheet AD8613/ AD8617/ AD8619 FEATURES PIN CONFIGURATIONS Offset voltage: 2.2 mV maximum OUT 1 5 V+ Low input bias current: 1 pA maximum AD8613 V– 2 TOP VIEW Single-supply operation: 1.8 V to 5.5 V
037
(Not to Scale) +IN 3 4 –IN Low noise: 22 nV/√Hz
05622-
Micropower: 50 μA/amplifier maximum over temperature
Figure 1. 5-Lead SC70 and 5-Lead TSOT-23
No phase reversal Unity gain stable OUT A 1 8 V+ AD8617 Qualified for automotive applications –IN A 2 7 OUT B TOP VIEW +IN A 3 6 –IN B (Not to Scale) APPLICATIONS V– 4 5 +IN B
05622-001
Battery-powered instrumentation
Figure 2. 8-Lead MSOP and 8-Lead SOIC_N
Multipole filters Current shunt sense OUT A 1 8 V+ Sensors –IN A 2 7 OUT B AD8617 ADC predrivers TOP VIEW +IN A 3 6 –IN B (Not to Scale) DAC drivers/level shifters V– 4 5 +IN B Low power ASIC input or output amplifiers NOTES GENERAL DESCRIPTION 1. PIN 4 AND THE EXPOSED PAD
002
MUST BE CONNECTED TO V–.
5622- 0 The AD8613/AD8617/AD8619 are single, dual, and quad micro- Figure 3. 8-Lead LFCSP power, rail-to-rail input and output amplifiers that feature low supply current, as well as low input voltage and current noise.
OUT A 1 14 OUT D
The parts are fully specified to operate from 1.8 V to 5 V single
–IN A 2 13 –IN D
supply, or ±0.9 V and ±2.5 V dual supply. The combination of low
+IN A 3 AD8619 12 +IN D TOP VIEW
noise, very low input bias currents, and low power consumption
V+ 4 11 V– (Not to Scale)
make the AD8613/AD8617/AD8619 especially useful in portable
+IN B 5 10 +IN C
and loop-powered instrumentation.
–IN B 6 9 –IN C
035
OUT B 7 8 OUT C
The ability to swing rail-to-rail at both the input and output 05622- enables designers to buffer CMOS ADCs, DACs, ASICs, and Figure 4. 14-Lead TSSOP and 14-Lead SOIC other wide output swing devices in low power, single-supply systems. The AD8613 is available in a 5-lead SC70 package and a 5-lead TSOT-23 package. The AD8617 is available in 8-lead MSOP, 8-lead SOIC, and 8-lead LFCSP packages. The AD8619 is available in 14-lead TSSOP and 14-lead SOIC packages. The AD8617W is qualified for automotive applications and is available in 8-lead MSOP and 8-lead SOIC packages. The AD8619W is qualified for automotive applications and is available in 14-lead SOIC and 14-lead TSSOP packages.
Rev. H Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2005–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
