Datasheet ADA4899-1 (Analog Devices) - 10
DescriptionUnity-Gain Stable, Ultralow Distortion, 1 nV/√Hz Voltage Noise, High Speed Op Amp
Pages / Page22 / 10 — ADA4899-1. Data Sheet. –40. G = +1. G = +5. –50. S = ±5V. L = 1kΩ. RL = …
RevisionC
File Format / SizePDF / 668 Kb
ADA4899-1. Data Sheet. –40. G = +1. G = +5. –50. S = ±5V. L = 1kΩ. RL = 1kΩ. –50 VS = ±5V. VOUT = 2V p-p. OUT = 2V p-p. –60. N (. –70. –80. HD3. –90. HD2
ADA4899-1 Data Sheet –40 G = +1 G = +5 –50 S = ±5V L = 1kΩ RL = 1kΩ –50 VS = ±5V VOUT = 2V p-p OUT = 2V p-p –60 N ( –70 –80 HD3 –90 HD2
ADA4899-1 Data Sheet –40 –40 G = +1 G = +5 V R –50 S = ±5V L = 1kΩ RL = 1kΩ –50 VS = ±5V VOUT = 2V p-p V c) OUT = 2V p-p –60 c) B B d –60 d N ( –70 N ( IO IO –70 RT –80 RT O O T T S HD3 –80 S –90 HD2 C DI HD2 C DI NI –90 NI O –100 O –100 –110 HARM HARM HD3
1
–120
4
–110
-02 -02 20 20 057
–130
057
–120 0.1 1 10 100 0.1 1 10 100 FREQUENCY (MHz) FREQUENCY (MHz)
Figure 17. Harmonic Distortion vs. Frequency Figure 20. Harmonic Distortion vs. Frequency
–40 –40 G = +1 G = +5 RL = 1kΩ VS = ±5V –50 f = 5MHz –50 RL = 100Ω VOUT = 2V p-p c) c) HD2 B –60 B –60 d d SOIC –V N ( N ( S ON PIN 4 IO –70 IO –70 RT RT HD2 O O HD2 LFCSP T –80 T SOIC S –80 S HD2 –VS ON PIN 5 C DI C DI –90 NI –90 NI O O HD3 –100 –100 HD3 HARM HARM HD3 SOIC LFCSP –VS ON PIN 4 OR PIN 5
2
–110
3
–110
-02 -04 20 20 057
–120
057
–120 1 2 3 4 5 6 7 8 0.1 1 10 100 OUTPUT AMPLITUDE (V p-p) FREQUENCY (MHz)
Figure 18. Harmonic Distortion vs. Output Amplitude Figure 21. Harmonic Distortion vs. Frequency for Various Pinouts and Packages
–40 –40 G = +1 G = +1 RL = 1kΩ VS = ±5V –50 VS = 5V –50 RL = 100Ω V c) OUT = 2V p-p c) B –60 d B –60 d N ( HD3 N ( IO –70 IO –70 RT RT O VOUT = 2V p-p T HD2 O –80 T S –80 S HD2 HD2 C DI C DI SOIC LFCSP –90 NI –90 NI O HD2 O HD3 –100 –100 HARM HARM HD3 VOUT = 1V p-p LFCSP OR SOIC
3
–110
4
–110
-02 -04 20 20 057
–120
057
Figure 19. Harmonic Distortion vs. Frequency Figure 22. Harmonic Distortion vs. Frequency for Both Packages Rev. C | Page 8 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION PACKAGING INNOVATION DISABLE\ PIN APPLICATIONS INFORMATION UNITY-GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE ADC DRIVER DISABLE\ PIN OPERATION ADA4899-1 MUX CIRCUIT CONSIDERATIONS PCB Layout Power Supply Bypassing Grounding OUTLINE DIMENSIONS ORDERING GUIDE
