Datasheet ADA4899-1 (Analog Devices) - 2
DescriptionUnity-Gain Stable, Ultralow Distortion, 1 nV/√Hz Voltage Noise, High Speed Op Amp
Pages / Page22 / 2 — ADA4899-1* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 668 Kb
ADA4899-1* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
ADA4899-1* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS
• SAR ADC & Driver Quick-Match Guide • Universal Evaluation Board for Single High Speed
Tutorials
Operational Amplifiers • MT-032: Ideal Voltage Feedback (VFB) Op Amp • MT-033: Voltage Feedback Op Amp Gain and Bandwidth
DOCUMENTATION
• MT-047: Op Amp Noise
Application Notes
• MT-048: Op Amp Noise Relationships: 1/f Noise, RMS • AN-0993: Active Filter Evaluation Board for Analog Noise, and Equivalent Noise Bandwidth Devices, Inc., - Low Distortion Pinout Op Amps • MT-049: Op Amp Total Output Noise Calculations for • AN-402: Replacing Output Clamping Op Amps with Input Single-Pole System Clamping Amps • MT-050: Op Amp Total Output Noise Calculations for • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease Second-Order System Design Constraints in Low Voltage High Speed Systems • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-581: Biasing and Decoupling Op Amps in Single Supply Applications • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, SFDR, MTPR • AN-649: Using the Analog Devices Active Filter Design Tool • MT-056: High Speed Voltage Feedback Op Amps • AN-931: Understanding PulSAR ADC Support Circuitry • MT-058: Effects of Feedback Capacitance on VFB and CFB Op Amps
Data Sheet
• MT-059: Compensating for the Effects of Input • ADA4899-1: Unity-Gain Stable, Ultralow Distortion, 1 nV/ Capacitance on VFB and CFB Op Amps Used in Current-to- √Hz Voltage Noise, High Speed Op Amp Data Sheet Voltage Converters
User Guides
• MT-060: Choosing Between Voltage Feedback and • UG-084: Evaluation Board for Single, High Speed Current Feedback Op Amps Operational Amplifiers (8-Lead, SOIC with Dedicated Feedback Pin and Exposed Paddle)
DESIGN RESOURCES
• UG-755: 8-Lead SOIC Amplifier Evaluation Board User • ADA4899-1 Material Declaration Guide • PCN-PDN Information • UG-919: Universal Evaluation Board for Single, 8-Lead LFCSP Operational Amplifiers • Quality And Reliability • Symbols and Footprints
TOOLS AND SIMULATIONS
• Analog Filter Wizard
DISCUSSIONS
• Analog Photodiode Wizard View all ADA4899-1 EngineerZone Discussions. • Power Dissipation vs Die Temp
SAMPLE AND BUY
• VRMS/dBm/dBu/dBV calculators • ADA4899 SPICE Macro Model Visit the product page to see pricing options.
REFERENCE DESIGNS TECHNICAL SUPPORT
• CN0080 Submit a technical question or find your regional support number. Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION PACKAGING INNOVATION DISABLE\ PIN APPLICATIONS INFORMATION UNITY-GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE ADC DRIVER DISABLE\ PIN OPERATION ADA4899-1 MUX CIRCUIT CONSIDERATIONS PCB Layout Power Supply Bypassing Grounding OUTLINE DIMENSIONS ORDERING GUIDE
