Datasheet ADA4899-1 (Analog Devices) - 5
DescriptionUnity-Gain Stable, Ultralow Distortion, 1 nV/√Hz Voltage Noise, High Speed Op Amp
Pages / Page22 / 5 — Data Sheet. ADA4899-1. SPECIFICATIONS WITH ±5 V SUPPLY. Table 1. …
RevisionC
File Format / SizePDF / 668 Kb
Data Sheet. ADA4899-1. SPECIFICATIONS WITH ±5 V SUPPLY. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADA4899-1 SPECIFICATIONS WITH ±5 V SUPPLY Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
TA = 25°C, G = +1, RL = 1 kΩ to ground, unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
DYNAMIC PERFORMANCE –3 dB Bandwidth VOUT = 25 mV p-p 600 MHz VOUT = 2 V p-p 80 MHz Bandwidth for 0.1 dB Flatness G = +2, VOUT = 2 V p-p 35 MHz Slew Rate VOUT = 5 V step 310 V/µs Settling Time to 0.1% VOUT = 2 V step 50 ns NOISE/DISTORTION PERFORMANCE Harmonic Distortion, HD2/HD3 (dBc) fC = 500 kHz, VOUT = 2 V p-p −123/−123 dBc fC = 10 MHz, VOUT = 2 V p-p −80/−86 dBc Input Voltage Noise f = 100 kHz 1.0 nV/√Hz Input Current Noise f = 100 kHz, DISABLE pin floating 2.6 pA/√Hz f = 100 kHz, DISABLE pin = +VS 5.2 pA/√Hz DC PERFORMANCE Input Offset Voltage 35 230 µV Input Offset Voltage Drift 5 µV/°C Input Bias Current DISABLE pin floating −6 −12 µA DISABLE pin = +VS −0.1 −1 µA Input Bias Current Drift 3 nA/°C Input Bias Offset Current 0.05 0.7 µA Open-Loop Gain 82 85 dB INPUT CHARACTERISTICS Input Resistance Differential mode 4 kΩ Common mode 7.3 MΩ Input Capacitance 4.4 pF Input Common-Mode Voltage Range −3.7 to +3.7 V Common-Mode Rejection Ratio 98 130 dB DISABLE PIN DISABLE Input Threshold Voltage Output disabled <2.4 V Turn-Off Time 50% of DISABLE voltage to 10% of VOUT, 100 ns VIN = 0.5 V Turn-On Time 50% of DISABLE voltage to 90% of VOUT, 40 ns VIN = 0.5 V Input Bias Current DISABLE = +VS (enabled) 17 21 µA DISABLE = −VS (disabled) −35 −44 µA OUTPUT CHARACTERISTICS Output Overdrive Recovery Time (Rise/Fal ) VIN = −2.5 V to +2.5 V, G = +2 30/50 ns Output Voltage Swing RL = 1 kΩ −3.65 to +3.65 −3.7 to +3.7 V RL = 100 Ω −3.13 to +3.15 −3.25 to +3.25 V Short-Circuit Current Sinking/sourcing 160/200 mA Off Isolation f = 1 MHz, DISABLE = −VS −48 dB POWER SUPPLY Operating Range 4.5 12 V Quiescent Current 14.7 16.2 mA Quiescent Current (Disabled) DISABLE = −VS 1.8 2.1 mA Positive Power Supply Rejection Ratio +VS = 4 V to 6 V (input referred) 84 90 dB Negative Power Supply Rejection Ratio −VS = −6 V to −4 V (input referred) 87 93 dB Rev. C | Page 3 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION PACKAGING INNOVATION DISABLE\ PIN APPLICATIONS INFORMATION UNITY-GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE ADC DRIVER DISABLE\ PIN OPERATION ADA4899-1 MUX CIRCUIT CONSIDERATIONS PCB Layout Power Supply Bypassing Grounding OUTLINE DIMENSIONS ORDERING GUIDE
