Datasheet ADA4899-1 (Analog Devices) - 6
DescriptionUnity-Gain Stable, Ultralow Distortion, 1 nV/√Hz Voltage Noise, High Speed Op Amp
Pages / Page22 / 6 — ADA4899-1. Data Sheet. SPECIFICATIONS WITH +5 V SUPPLY. Table 2. …
RevisionC
File Format / SizePDF / 668 Kb
ADA4899-1. Data Sheet. SPECIFICATIONS WITH +5 V SUPPLY. Table 2. Parameter. Test Conditions/Comments. Min. Typ. Max Unit
ADA4899-1 Data Sheet SPECIFICATIONS WITH +5 V SUPPLY Table 2 Parameter Test Conditions/Comments Min Typ Max Unit
VS = 5 V at TA = 25°C, G = +1, RL = 1 kΩ to midsupply, unless otherwise noted.
Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
DYNAMIC PERFORMANCE –3 dB Bandwidth VOUT = 25 mV p-p 535 MHz VOUT = 2 V p-p 60 MHz Bandwidth for 0.1 dB Flatness G = +2, VOUT = 2 V p-p 25 MHz Slew Rate VOUT = 2 V step 185 V/µs Settling Time to 0.1% VOUT = 2 V step 50 ns NOISE/DISTORTION PERFORMANCE Harmonic Distortion, HD2/HD3 (dBc) fC = 500 kHz, VOUT = 1 V p-p −100/−113 dBc fC = 10 MHz, VOUT = 1 V p-p −89/−100 dBc Input Voltage Noise f = 100 kHz 1.0 nV/√Hz Input Current Noise f = 100 kHz, DISABLE pin floating 2.6 pA/√Hz f = 100 kHz, DISABLE pin = +VS 5.2 pA/√Hz DC PERFORMANCE Input Offset Voltage 5 210 µV Input Offset Voltage Drift 5 µV/°C Input Bias Current DISABLE pin floating −6 −12 µA DISABLE pin = +VS −0.2 −1.5 µA Input Bias Offset Current 0.05 µA Input Bias Offset Current Drift 2.5 nA/°C Open-Loop Gain 76 80 dB INPUT CHARACTERISTICS Input Resistance Differential mode 4 kΩ Common mode 7.7 MΩ Input Capacitance 4.4 pF Input Common-Mode Voltage Range 1.3 to 3.7 V Common-Mode Rejection Ratio 90 114 dB DISABLE PIN DISABLE Input Threshold Voltage Output disabled <2.4 V Turn-Off Time 50% of DISABLE voltage to 10% of VOUT, 100 ns VIN = 0.5 V Turn-On Time 50% of DISABLE voltage to 90% of VOUT, 60 ns VIN = 0.5 V Input Bias Current DISABLE = +VS (enabled) 16 18 µA DISABLE = −VS (disabled) −33 −42 µA OUTPUT CHARACTERISTICS Overdrive Recovery Time (Rise/Fall) VIN = 0 V to 2.5 V, G = +2 50/70 ns Output Voltage Swing RL = 1 kΩ 1.25 to 3.75 1.2 to 3.8 V RL = 100 Ω 1.4 to 3.6 1.35 to 3.65 V Short-Circuit Current Sinking/sourcing 60/80 mA Off Isolation f = 1 MHz, DISABLE = −VS −48 dB POWER SUPPLY Operating Range 4.5 12 V Quiescent Current 14.3 16 mA Quiescent Current (Disabled) DISABLE = −VS 1.5 1.7 mA Positive Power Supply Rejection Ratio +VS = 4.5 V to 5.5 V, −VS = 0 V (input referred) 84 90 dB Negative Power Supply Rejection Ratio +VS = 5 V, −VS = −0.5 V to +0.5 V (input referred) 86 90 dB Rev. C | Page 4 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION PACKAGING INNOVATION DISABLE\ PIN APPLICATIONS INFORMATION UNITY-GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE ADC DRIVER DISABLE\ PIN OPERATION ADA4899-1 MUX CIRCUIT CONSIDERATIONS PCB Layout Power Supply Bypassing Grounding OUTLINE DIMENSIONS ORDERING GUIDE
