Datasheet ADA4862-3 (Analog Devices) - 8
DescriptionHigh Speed, G = +2, Low Cost, Triple Op Amp
Pages / Page17 / 8 — ADA4862-3. VS =. 1.5. 4.0. G = +2. INPUT VOLTAGE. L = 150. CL = 4pF. 1.0. …
File Format / SizePDF / 305 Kb
ADA4862-3. VS =. 1.5. 4.0. G = +2. INPUT VOLTAGE. L = 150. CL = 4pF. 1.0. 3.5. f = 1MHz. VOUT. S = +5V. LTAGE O. 0.5. 3.0. T V. = 0V. S =. = 5V. 2.5. = 5V,
ADA4862-3 VS = 1.5 4.0 G = +2 INPUT VOLTAGE L = 150 CL = 4pF 1.0 3.5 f = 1MHz VOUT S = +5V LTAGE O 0.5 3.0 T V = 0V S = = 5V 2.5 = 5V,
ADA4862-3 6 VS =
5V 1.5 4.0 5 G = +2 INPUT VOLTAGE
2 ) R 4 L = 150
Ω
(V CL = 4pF 1.0 3.5 3 f = 1MHz VOUT V 2 S = +5V LTAGE O 0.5 3.0 1 T V = 0V U S V 0 S =
5V –V = 5V 0 2.5 –1 S
V = 5V, –2 S UT AND INP –0.5 2.0 +V –3 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) G = +2 OUTP –4 RL = 150
Ω
–1.0 CL = 4pF 1.5 –5 VOUT = 2V p-p TIME = 5ns/DIV –6
05600-042
0 100 200 300 400 500 600 700 800 900 1000 –1.5 1.0
05600-010
TIME (ns)
Figure 10. Large Signal Transient Response for Various Supplies Figure 13. Input Overdrive Recovery
5.5 VS = 5V 1.5 5.0 G = +2 C INPUT VOLTAGE
2 L = 9pF ) R 4.5 L = 150
Ω
C C L = 6pF (V L = 4pF 1.0 4.0 f = 1MHz VOUT 3.5 C LTAGE L = 4pF O 0.5 3.0 T V U 2.5 0 2.0 1.5 UT AND INP –0.5 G = +2 1.0 OUTPUT VOLTAGE (V) RL = 150
Ω
CL = 4pF OUTP 0.5 VOUT = 2V p-p –1.0 V 0 S =
5V TIME = 5ns/DIV –0.5
05600-041
05600-018
TIME (ns)
Figure 11. Large Signal Transient Response for Various Capacitor Loads Figure 14. Output Overdrive Recovery
4.0 CL = 9pF CL = 6pF 3.5 CL = 4pF 3.0 2.5 2.0 G = +2 OUTPUT VOLTAGE (V) RL = 150
Ω
CL = 4pF VOUT = 2V p-p 1.5 VS = 5V TIME = 5ns/DIV 1.0
05600-019 Figure 12. Large Signal Transient Response for Various Capacitor Loads Rev. A | Page 7 of 16 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS USING THE ADA4862-3 IN GAINS = +1, −1 Unity-Gain Operation (Option 1) Option 2 VIDEO LINE DRIVER SINGLE-SUPPLY OPERATION POWER DOWN LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING OUTLINE DIMENSIONS ORDERING GUIDE
