Datasheet ADA4862-3 (Analog Devices) - 9 Manufacturer Analog Devices Description High Speed, G = +2, Low Cost, Triple Op Amp Pages / Page 17 / 9 — ADA4862-3. 1.5. VS =. 5V, +5V G = +2. VOUT. 1.0. OUT = 2V p-p. RL =150. … Revision A File Format / Size PDF / 305 Kb Document Language English
ADA4862-3. 1.5. VS =. 5V, +5V G = +2. VOUT. 1.0. OUT = 2V p-p. RL =150. OUT. L = 4pF. ) V. 0.5. (V). EXPANDED. D (mV. D (m. ANDE. AND V. AND V T. –0.5. –10
Model Line for this Datasheet Text Version of Document ADA4862-3 1.5 20 1.5 20 VS = ±5V, +5V G = +2 VOUT 15 15 V 1.0 OUT = 2V p-p 1.0 RL =150 ΩV C OUT L = 4pF 10 10 V ) IN ) V ) 0.5 V 0.5 (V OUT V 5 (V) 5 IN EXPANDED D (mV D (m IN IN 0 0 0 0 ANDE ANDE AND V P P X AND V T X E E –5 OUT –5 OU T V –0.5 V –0.5 VOUT OUT OU V EXPANDED V –10 VS = ±5V, +5V –10 G = +2 –1.0 –1.0 VOUT = 2V p-p –15 –15 RL = 150 ΩCL = 4pF –1.5 –20 –1.5 –20 0 5 10 15 20 25 30 35 40 45 50 0 5 10 15 20 25 30 35 40 45 50 05600-043 05600-046TIME (ns) TIME (ns) Figure 15. Settling Time Falling Edge Figure 18. Settling Time Rising Edge1600 800 G = +2 G = +2 V V 1400 S = ±5V S = 5V R POSITIVE SLEW RATE 700 POSITIVE SLEW RATE L = 150 ΩRL = 150 ΩCL = 4pF CL = 4pF 1200 600 NEGATIVE SLEW RATE / μs) 1000 / μs) 500 V V E ( T NEGATIVE SLEW RATE A 800 400 R 600 300 SLEW SLEW RATE ( 400 200 200 100 0 05600-0050 05600-0060 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 0 0.5 1.0 1.5 2.0 2.5 3.0 OUTPUT VOLTAGE STEP (V p-p) OUTPUT VOLTAGE STEP (V p-p) Figure 16. Slew Rate vs. Output Voltage Figure 19. Slew Rate vs. Output Voltage100 0 G = +2 G = +2 RL = 150 ΩRL = 150 ΩCL = 4pF CL = 4pF V –20 OUT = 2V p-p VOUT = 2V p-p ) VS = ±5V VS = ±5V z V V H S = +5V S = +5V V/ B) –40 n d OISE ( 10 –60 GE N CROSSTALK ( –80 VOLTA –100 1 05600-037–120 05600-02310 100 1k 10k 100k 1M 10M 100M 0.1 1 10 100 1000 FREQUENCY (Hz) FREQUENCY (MHz) Figure 17. Voltage Noise vs. Frequency Referred to Output (RTO) Figure 20. Large Signal Crosstalk Rev. A | Page 8 of 16 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS USING THE ADA4862-3 IN GAINS = +1, −1 Unity-Gain Operation (Option 1) Option 2 VIDEO LINE DRIVER SINGLE-SUPPLY OPERATION POWER DOWN LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING OUTLINE DIMENSIONS ORDERING GUIDE
