Datasheet AD8397 (Analog Devices) - 2
DescriptionRail-to-Rail, High Output Current Amplifier
Pages / Page17 / 2 — AD8397* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 259 Kb
AD8397* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8397* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• Universal Evaluation Board for Dual High Speed • MT-032: Ideal Voltage Feedback (VFB) Op Amp Operational Amplifiers • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • MT-047: Op Amp Noise
DOCUMENTATION
• MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
Application Notes
Noise, and Equivalent Noise Bandwidth • AN-1429: Design Considerations and Solutions for • MT-049: Op Amp Total Output Noise Calculations for Headphone Drivers in Mobile Phones Single-Pole System • AN-1439: One-Stage Amplifier Design Consideration of a • MT-050: Op Amp Total Output Noise Calculations for High Fidelity System Second-Order System • AN-402: Replacing Output Clamping Op Amps with Input • MT-052: Op Amp Noise Figure: Don't Be Misled Clamping Amps • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease SFDR, MTPR Design Constraints in Low Voltage High Speed Systems • MT-056: High Speed Voltage Feedback Op Amps • AN-581: Biasing and Decoupling Op Amps in Single Supply Applications • MT-058: Effects of Feedback Capacitance on VFB and CFB Op Amps
Data Sheet
• MT-060: Choosing Between Voltage Feedback and • AD8397: Rail-to-Rail, High Output Current Amplifier Data Current Feedback Op Amps Sheet
User Guides DESIGN RESOURCES
• UG-128: Universal Evaluation Board for Dual High Speed • AD8397 Material Declaration Op Amps in SOIC Packages • PCN-PDN Information
TOOLS AND SIMULATIONS
• Quality And Reliability • Analog Filter Wizard • Symbols and Footprints • Analog Photodiode Wizard
DISCUSSIONS
• Power Dissipation vs Die Temp View all AD8397 EngineerZone Discussions. • VRMS/dBm/dBu/dBV calculators • AD8397 SPICE Macro Model
SAMPLE AND BUY REFERENCE DESIGNS
Visit the product page to see pricing options. • CN0276
TECHNICAL SUPPORT
• CN0317 Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER SUPPLY AND DECOUPLING LAYOUT CONSIDERATIONS UNITY-GAIN OUTPUT SWING CAPACITIVE LOAD DRIVE OUTLINE DIMENSIONS ORDERING GUIDE
