Datasheet AD8625, AD8626, AD8627 (Analog Devices)
Description | Precision Low Power Single-Supply JFET Amplifiers |
Pages / Page | 20 / 1 — Precision Low Power. Single-Supply JFET Amplifiers. Data Sheet. AD8625/. … |
Revision | F |
File Format / Size | PDF / 290 Kb |
Precision Low Power. Single-Supply JFET Amplifiers. Data Sheet. AD8625/. AD8626/. AD8627. FEATURES. PIN CONFIGURATIONS. SC70 package
Precision Low Power Single-Supply JFET Amplifiers Data Sheet AD8625/ AD8626/ AD8627 FEATURES PIN CONFIGURATIONS SC70 package 8-Lead SOIC 5-Lead SC70 (R-8 Suffix) (KS Suffix) Very low IB: 1 pA max Single-supply operation: 5 V to 26 V OUT A 1 5 V+ NC 1 8 NC Dual-supply operation: ±2.5 V to ±13 V V– 2 AD8627 –IN 2 7 V+ Rail-to-rail output AD8627 +IN 3 4 –IN +IN 3 6 OUT Low supply current: 630 μA/amp typ Low offset voltage: 500 μV max V– 4 5 NC Unity gain stable NC = NO CONNECT No phase reversal 8-Lead SOIC 8-Lead MSOP (R-8 Suffix) (RM-Suffix) APPLICATIONS OUT A 1 8 V+ OUT A 1 8 V+ Photodiode amplifiers –IN A OUT B –IN A 2 7 OUT B AD8626 ATEs +IN A –IN B AD8626 V– 4 5 +IN B Line-powered/battery-powered instrumentation +IN A 3 6 –IN B Industrial controls V– 4 5 +IN B Automotive sensors Precision filters Audio 14-Lead SOIC 14-Lead TSSOP (R-Suffix) (RU-Suffix) OUT A 1 14 OUT D OUT A 1 14 OUT D –IN A –IN D –IN A 2 13 –IN D +IN A +IN D +IN A 3 12 +IN D V+ AD8625 V– AD8625 +IN B +IN C V+ 4 11 V– –IN B –IN C +IN B 5 10 +IN C OUT B 7 8 OUT C –IN B 6 9 –IN C OUT B 7 8 OUT C
03023-001 Figure 1.
GENERAL DESCRIPTION
The AD862x is a precision JFET input amplifier. It features The 5 MHz bandwidth and low offset are ideal for precision filters. true single-supply operation, low power consumption, and The AD862x is fully specified over the industrial temperature rail-to-rail output. The outputs remain stable with capacitive range. (−40°C to +85°C). The AD8627 is available in both loads of over 500 pF; the supply current is less than 630 μA/amp. 5-lead SC70 and 8-lead SOIC surface-mount packages (SC70 Applications for the AD862x include photodiode transimpedance packaged parts are available in tape and reel only). The AD8626 amplification, ATE reference level drivers, battery management, is available in MSOP and SOIC packages, while the AD8625 is both line powered and portable instrumentation, and remote available in TSSOP and SOIC packages. sensor signal conditioning, which includes automotive sensors. The AD862x’s ability to swing nearly rail-to-rail at the input and rail-to-rail at the output enables it to be used to buffer CMOS DACs, ASICs, and other wide output swing devices in single-supply systems.
Rev. F Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2003–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Pin Configurations General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Applications Information Minimizing Input Current Photodiode Preamplifier Application Output Amplifier for DACs Eight-Pole Sallen Key Low-Pass Filter Outline Dimensions Ordering Guide
