Datasheet AD8099 (Analog Devices) - 2
DescriptionUltralow Distortion, High Speed 0.95nV/√Hz Voltage Noise Op Amp
Pages / Page28 / 2 — AD8099* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionE
File Format / SizePDF / 667 Kb
AD8099* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8099* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• Universal Evaluation Board for Single High Speed • MT-032: Ideal Voltage Feedback (VFB) Op Amp Operational Amplifiers • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • MT-047: Op Amp Noise
DOCUMENTATION
• MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
Application Notes
Noise, and Equivalent Noise Bandwidth • AN-0993: Active Filter Evaluation Board for Analog • MT-049: Op Amp Total Output Noise Calculations for Devices, Inc., - Low Distortion Pinout Op Amps Single-Pole System • AN-402: Replacing Output Clamping Op Amps with Input • MT-050: Op Amp Total Output Noise Calculations for Clamping Amps Second-Order System • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-052: Op Amp Noise Figure: Don't Be Misled Design Constraints in Low Voltage High Speed Systems • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, • AN-581: Biasing and Decoupling Op Amps in Single SFDR, MTPR Supply Applications • MT-056: High Speed Voltage Feedback Op Amps • AN-649: Using the Analog Devices Active Filter Design Tool • MT-058: Effects of Feedback Capacitance on VFB and CFB Op Amps
Data Sheet
• MT-059: Compensating for the Effects of Input • AD8099: Ultralow Distortion, High Speed, 0.95 nV/√Hz Capacitance on VFB and CFB Op Amps Used in Current-to- Voltage Noise Op Amp Data Sheet Voltage Converters
User Guides
• MT-101: Decoupling Techniques • UG-755: 8-Lead SOIC Amplifier Evaluation Board User Guide
DESIGN RESOURCES
• AD8099 Material Declaration
TOOLS AND SIMULATIONS
• PCN-PDN Information • Analog Filter Wizard • Quality And Reliability • Analog Photodiode Wizard • Symbols and Footprints • Power Dissipation vs Die Temp • VRMS/dBm/dBu/dBV calculators
DISCUSSIONS
• AD8099 SPICE Macro Model View all AD8099 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number. Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAMS REVISION HISTORY SPECIFICATIONS SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION USING THE AD8099 CIRCUIT COMPONENTS RECOMMENDED VALUES CIRCUIT CONFIGURATIONS PERFORMANCE vs. COMPONENT VALUES TOTAL OUTPUT NOISE CALCULATIONS AND DESIGN INPUT BIAS CURRENT AND DC OFFSET PIN AND INPUT BIAS CANCELLATION 16-BIT ADC DRIVER CIRCUIT CONSIDERATIONS PCB Layout Parasitics Grounding Power Supply Bypassing Component Selection DESIGN TOOLS AND TECHNICAL SUPPORT OUTLINE DIMENSIONS ORDERING GUIDE
