Datasheet AD8605, AD8606, AD8608 (Analog Devices) - 9
Description | Low Noise, CMOS, Rail-to-Rail, Input/Output Precision Quad Op Amp |
Pages / Page | 24 / 9 — Data Sheet. AD8605/AD8606/AD8608. TYPICAL PERFORMANCE CHARACTERISTICS. … |
Revision | O |
File Format / Size | PDF / 850 Kb |
Data Sheet. AD8605/AD8606/AD8608. TYPICAL PERFORMANCE CHARACTERISTICS. 4500. 0.30. S = 5V. 0.25. 4000 TA = 25°C. VCM = 0V TO 5V. 0.20. 3500
Data Sheet AD8605/AD8606/AD8608 TYPICAL PERFORMANCE CHARACTERISTICS 4500 0.30 V V S = 5V S = 5V 0.25 4000 TA = 25°C VCM = 0V TO 5V 0.20 3500 0.15 S R 3000 0.10 LIFIE ) P 0.05 2500 V M m A ( 0 F 2000 OSV –0.05 R O BE 1500 –0.10 NUM –0.15 1000 –0.20 500
007 010
–0.25 0
02731- 02731-
–0.30 –300 –200 –100 0 100 200 300 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 OFFSET VOLTAGE (µV) VCM (V)
Figure 7. Input Offset Voltage Distribution Figure 10. Input Offset Voltage vs. Common-Mode Voltage (200 Units, 5 Wafer Lots, Including Process Skews)
24 250 VS = 5V VSY = 5V TA = –40°C TO +125°C 200 VCM = VSY/2 20 VCM = 2.5V S 150 A) R p 16 ( LIFIE NT 100 P M A 12 F 50 CURRE R O AS 0 BE BI 8 UT NUM –50 INP 4 AD8605 –100 AD8606
008
AD8608 0
02731-
–150 0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0 4.4 4.8 –50 –25 0 25 50 75 100 125
011
TCVOS (µV/°C) TEMPERATURE (°C)
02731- Figure 8. AD8608 Input Offset Voltage Drift Distribution Figure 11. Input Bias Current vs. Temperature
1k 20 V V S = 5V S = 5V 18 T T A = –40°C TO +125°C A = 25°C V) VCM = 2.5V 16 E (m 100 S G R A 14 LT O LIFIE V P 12 M A 10 10 TION F A R O 8 UR T SOURCE SINK BE A 6 T S NUM U 1 4 TP OU 2
012 009
0.1
02731-
0
02731-
0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 0.001 0.01 0.1 1 10 TCVOS (µV/°C) LOAD CURRENT (mA)
Figure 9. AD8605/AD8606 Input Offset Voltage Drift Distribution Figure 12. Output Saturation Voltage vs. Load Current Rev. N | Page 9 of 24 Document Outline Features Applications General Description Pin Configurations Revision History 5 V Electrical Specifications 2.7 V Electrical Specifications Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Applications Information Output Phase Reversal Maximum Power Dissipation Input Overvoltage Protection THD + Noise Total Noise Including Source Resistors Channel Separation Capacitive Load Drive Light Sensitivity WLCSP Assembly Considerations I-V Conversion Applications Photodiode Preamplifier Applications Audio and PDA Applications Instrumentation Amplifiers DAC Conversion Outline Dimensions Ordering Guide
