Datasheet AD8007, AD8008 (Analog Devices)
Description | Ultralow Distortion, High Speed Amplifiers |
Pages / Page | 20 / 1 — Ultralow Distortion,. High Speed Amplifiers. AD8007/AD8008. FEATURES. … |
Revision | E |
File Format / Size | PDF / 374 Kb |
Ultralow Distortion,. High Speed Amplifiers. AD8007/AD8008. FEATURES. CONNECTION DIAGRAMS. Extremely low distortion. AD8007
Ultralow Distortion, High Speed Amplifiers AD8007/AD8008 FEATURES CONNECTION DIAGRAMS Extremely low distortion AD8007 Second harmonic NC 1 (Top View) 8 NC −88 dBc @ 5 MHz –IN 2 7 +VS −83 dBc @ 20 MHz (AD8007) +IN 3 6 VOUT −77 dBc @ 20 MHz (AD8008) –VS 4 5 NC Third harmonic
1 00
−101 dBc @ 5 MHz
6-
NC = NO CONNECT
86 02
−92 dBc @ 20 MHz (AD8007)
Figure 1. 8-Lead SOIC (R)
−98 dBc @ 20 MHz (AD8008) High speed AD8007 VOUT 1 5 (Top View) +VS 650 MHz, −3 dB bandwidth (G = +1) –V 1000 V/μs slew rate 2 S Low noise
2 0
+IN 3 4 –IN
0 6-
2.7 nV/√Hz input voltage noise
86 02
22.5 pA/√Hz input inverting current noise
Figure 2. 5-Lead SC70 (KS)
Low power: 9 mA/amplifier typical supply current AD8008 Wide supply voltage range: 5 V to 12 V (Top View) V 1 OUT1 8 +VS 0.5 mV typical input offset voltage –IN1 2 7 VOUT2 Small packaging: 8-lead SOIC, 8-lead MSOP, and 5-lead SC70 +IN1 3 6 –IN2 APPLICATIONS –V
3
S 4 5 +IN2
-00 866
Instrumentation
02
IF and baseband amplifiers
Figure 3. 8-Lead SOIC (R) and 8-Lead MSOP (RM)
Filters A/D drivers DAC buffers GENERAL DESCRIPTION
The AD8007 is available in a tiny SC70 package as well as a The AD8007 (single) and AD8008 (dual) are high performance standard 8-lead SOIC. The dual AD8008 is available in both an current feedback amplifiers with ultralow distortion and noise. 8-lead SOIC and an 8-lead MSOP. These amplifiers are rated to Unlike other high performance amplifiers, the low price and work over the industrial temperature range of −40°C to +85°C. low quiescent current allow these amplifiers to be used in a
–30 G = +2
wide range of applications. Analog Devices, Inc., proprietary
R –40 L = 150Ω VS = ±5V
second-generation eXtra-Fast Complementary Bipolar (XFCB)
VOUT = 2V p-p
process enables such high performance amplifiers with low power
–50
consumption.
c) –60 (dB
The AD8007/AD8008 have 650 MHz bandwidth, 2.7 nV/√Hz
TION –70
voltage noise, −83 dB SFDR at 20 MHz (AD8007), and −77 dBc
R TO SECOND
SFDR at 20 MHz (AD8008).
S –80 DI
With the wide supply voltage range (5 V to 12 V) and wide
–90
bandwidth, the AD8007/AD8008 are designed to work in a
THIRD –100
variety of applications. The AD8007/AD8008 amplifiers have a low power supply current of 9 mA/amplifier.
–110
4
1 10 100
006-
FREQUENCY (MHz)
86 02 Figure 4. AD8007 Second and Third Harmonic Distortion vs. Frequency
Rev. E Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2002–2009 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VS = ±5 V VS = 5 V ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION OUTPUT SHORT CIRCUIT ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD8007/AD8008 Supply Decoupling for Low Distortion LAYOUT CONSIDERATIONS LAYOUT AND GROUNDING CONSIDERATIONS GROUNDING INPUT CAPACITANCE OUTPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING EXTERNAL COMPONENTS AND STABILITY OUTLINE DIMENSIONS ORDERING GUIDE
