Datasheet AD8007, AD8008 (Analog Devices) - 3
DescriptionUltralow Distortion, High Speed Amplifiers
Pages / Page20 / 3 — AD8007/AD8008. SPECIFICATIONS VS = ±5 V. Table 1. Parameter. Conditions. …
RevisionE
File Format / SizePDF / 374 Kb
AD8007/AD8008. SPECIFICATIONS VS = ±5 V. Table 1. Parameter. Conditions. Min. Typ. Max. Unit
AD8007/AD8008 SPECIFICATIONS VS = ±5 V Table 1 Parameter Conditions Min Typ Max Unit
TA = 25°C, RS = 200 Ω, RL = 150 Ω, RF = 499 Ω, Gain = +2, unless otherwise noted.
Table 1. AD8007/AD8008 Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth G = +1, VO = 0.2 V p-p, RL = 1 kΩ 540 650 MHz G = +1, VO = 0.2 V p-p, RL = 150 Ω 250 500 MHz G = +2, VO = 0.2 V p-p, RL = 150 Ω 180 230 MHz G = +1, VO = 2 V p-p, RL = 1 kΩ 200 235 MHz Bandwidth for 0.1 dB Flatness VO = 0.2 V p-p, G = +2, RL = 150 Ω 50 90 MHz Overdrive Recovery Time ±2.5 V input step, G = +2, RL = 1 kΩ 30 ns Slew Rate G = +1, VO = 2 V step 900 1000 V/μs Settling Time to 0.1% G = +2, VO = 2 V step 18 ns Settling Time to 0.01% G = +2, VO = 2 V step 35 ns NOISE/HARMONIC PERFORMANCE Second Harmonic fC = 5 MHz, VO = 2 V p-p −88 dBc fC = 20 MHz, VO = 2 V p-p −83/−77 dBc Third Harmonic fC = 5 MHz, VO = 2 V p-p −101 dBc IMD fC = 20 MHz, VO = 2 V p-p −92/−98 dBc fC = 19.5 MHz to 20.5 MHz, RL = 1 kΩ, VO = 2 V p-p −77 dBc Third-Order Intercept fC = 5 MHz, RL = 1 kΩ 43.0/42.5 dBm fC = 20 MHz, RL = 1 kΩ 42.5 dBm Crosstalk (AD8008) f = 5 MHz, G = +2 −68 dB Input Voltage Noise f = 100 kHz 2.7 nV/√Hz Input Current Noise −Input, f = 100 kHz 22.5 pA/√Hz +Input, f = 100 kHz 2 pA/√Hz Differential Gain Error NTSC, G = +2, RL = 150 Ω 0.015 % Differential Phase Error NTSC, G = +2, RL = 150 Ω 0.010 Degree DC PERFORMANCE Input Offset Voltage 0.5 4 mV Input Offset Voltage Drift 3 μV/°C Input Bias Current +Input 4 8 μA −Input 0.4 6 μA Input Bias Current Drift +Input 16 nA/°C −Input 9 nA/°C Transimpedance VO = ±2.5 V, RL = 1 kΩ 1.0 1.5 MΩ RL = 150 Ω 0.4 0.8 MΩ INPUT CHARACTERISTICS Input Resistance +Input 4 MΩ Input Capacitance +Input 1 pF Input Common-Mode Voltage Range −3.9 to +3.9 V Common-Mode Rejection Ratio VCM = ±2.5 V 56 59 dB OUTPUT CHARACTERISTICS Output Saturation Voltage VCC − VOH, VOL − VEE, RL = 1 kΩ 1.1 1.2 V Short-Circuit Current, Source 130 mA Short-Circuit Current, Sink 90 mA Capacitive Load Drive 30% overshoot 8 pF Rev. E | Page 3 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VS = ±5 V VS = 5 V ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION OUTPUT SHORT CIRCUIT ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD8007/AD8008 Supply Decoupling for Low Distortion LAYOUT CONSIDERATIONS LAYOUT AND GROUNDING CONSIDERATIONS GROUNDING INPUT CAPACITANCE OUTPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING EXTERNAL COMPONENTS AND STABILITY OUTLINE DIMENSIONS ORDERING GUIDE
