Datasheet AD8007, AD8008 (Analog Devices) - 8
DescriptionUltralow Distortion, High Speed Amplifiers
Pages / Page20 / 8 — AD8007/AD8008. 10M. G = +2. 20pF. 20pF AND. 10Ω SNUB. 20Ω SNUB. …
RevisionE
File Format / SizePDF / 374 Kb
AD8007/AD8008. 10M. G = +2. 20pF. 20pF AND. 10Ω SNUB. 20Ω SNUB. TRANSIMPEDANCE. ) Ω 100k. –30. PHASE. ) 6. 10k. –90. rees). E P. ( E. –150. 499Ω. –180. HAS. 0pF
AD8007/AD8008 10M G = +2 20pF 20pF AND 10Ω SNUB 20Ω SNUB TRANSIMPEDANCE ) Ω 100k –30 PHASE ) 6 10k –90 rees) E P ( E –150 499Ω –180 HAS 0pF
AD8007/AD8008 10 10M 90 G = +2 20pF 9 20pF AND 20pF AND 10Ω SNUB 1M 30 8 20Ω SNUB TRANSIMPEDANCE 0 7 ) Ω 100k –30 ( PHASE ) 6 CE B 10k –90 rees) d AN ( eg 5 D D IN E P ( E GA 1k –150 4 499Ω IM –180 HAS 499Ω 0pF P 3 RSNUB RANS T 100 –210 200Ω 2 CLOAD 49.9Ω 10 –270 1 0 1 –330 1 10 100 1000
12 15 0
10k 100k 1M 10M 100M 1G 2G
0 6- 6-
FREQUENCY (MHz)
86
FREQUENCY (Hz)
286 02 0 Figure 12. Small Signal Frequency Response for Figure 15. Transimpedance and Phase vs. Frequency Capacitive Load and Snub Resistor
3 9 G = +1 VS = +5V, +85°C G = +2 2 V 8 S = ±5V, +85°C 1 7 VS = +5V, +85°C 0 6 VS = ±5V, +85°C ) –1 B ) 5 d B ( V d –2 S = +5V, –40°C ( VS = +5V, –40°C IN 4 IN GA –3 VS = ±5V, –40°C V GA 3 S = ±5V, –40°C –4 2 –5 1 –6 0 –7 –1 10 100 1000
130
10 100 1000
160 6- 6-
FREQUENCY (MHz)
286
FREQUENCY (MHz)
86 0 02 Figure 13. Small Signal Frequency Response over Temperature, Figure 16. Small Signal Frequency Response over Temperature, VS = +5 V, VS = ±5 V VS = +5 V, VS = ±5 V
3 9 VOUT = 2V p-p G = +2 2 8 1 G = +1 G = +2 7 B) d 0 6 N ( AI –1 ) 5 B d D G G = +10 ( E –2 4 IZ IN G = –1 A RL = 150Ω, VS = ±5V, VO = 2V p-p AL –3 G 3 RM RL = 1kΩ, VS = ±5V, VO = 2V p-p –4 2 NO RL = 150Ω, VS = +5V, VO = 1V p-p –5 1 RL = 1kΩ, VS = +5V, VO = 1V p-p –6 0 –7 –1
7
1 10 100 1000
140
10 100 1000
01 6- 6-
FREQUENCY (MHz)
86
FREQUENCY (MHz)
86 02 02 Figure 14. Large Signal Frequency Response for Various Gains Figure 17. Large Signal Frequency Response for VS and RL Rev. E | Page 8 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VS = ±5 V VS = 5 V ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION OUTPUT SHORT CIRCUIT ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD8007/AD8008 Supply Decoupling for Low Distortion LAYOUT CONSIDERATIONS LAYOUT AND GROUNDING CONSIDERATIONS GROUNDING INPUT CAPACITANCE OUTPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING EXTERNAL COMPONENTS AND STABILITY OUTLINE DIMENSIONS ORDERING GUIDE
