Datasheet AD8610, AD8620 (Analog Devices) - 6
DescriptionLow Input Bias Current, Wide BW JFET Precision Dual Op Amp
Pages / Page24 / 6 — AD8610/AD8620. TYPICAL PERFORMANCE CHARACTERISTICS. 600. VS = ±13V. VS = …
RevisionF
File Format / SizePDF / 374 Kb
AD8610/AD8620. TYPICAL PERFORMANCE CHARACTERISTICS. 600. VS = ±13V. VS = ±5V. 400. E (. 200. SET. B M. O T. –200. PU IN. –400. –600. –250. –150. –50. 150
AD8610/AD8620 TYPICAL PERFORMANCE CHARACTERISTICS 600 VS = ±13V VS = ±5V 400 E ( 200 SET B M O T –200 PU IN –400 –600 –250 –150 –50 150
AD8610/AD8620 TYPICAL PERFORMANCE CHARACTERISTICS 14 600 VS = ±13V VS = ±5V 12 ) 400 V S µ R 10 E ( IE G 200 IF A L T P L M 8 A VO 0 OF SET R 6 F E F B M O T –200 U 4 N PU IN 2 –400
03 06 0 0 0- 0- 73 73 02
0
02
–600 –250 –150 –50 50 150 250 –40 25 85 125 INPUT OFFSET VOLTAGE (µV) TEMPERATURE (°C)
Figure 3. Input Offset Voltage Figure 6. Input Offset Voltage vs. Temperature at ±5 V (300 Amplifiers)
600 14 V V S = ±13V S = ±5V OR ±13V 12 400 V) µ ( S E R 10 G IE A 200 IF T L L P M 8 VO 0 A ET S OF F R 6 F E O B T –200 M U U 4 P N IN –400 2
4 07 00 0 0- 0- 73 273 02
–600
0
0 –40 25 85 125 0 0.2 0.6 1.0 1.4 1.8 2.2 2.6 TEMPERATURE (°C) TCVOS (µV/°C)
Figure 4. Input Offset Voltage vs. Temperature at ±13 V (300 Amplifiers) Figure 7. Input Offset Voltage Drift
18 3.6 V VS = ±13V 16 S = ±5V 3.4 14 A) 3.2 RS p IE ( 12 IF L NT 3.0 P 10 RE AM F 2.8 CUR 8 R O AS BI 2.6 BE 6 UT NUM 2.4 4 INP 2 2.2
05 08 0 0 0- 0- 73 273 0
0 2.0
02
–250 –150 –50 50 150 250 –10 –5 0 5 10 INPUT OFFSET VOLTAGE (µV) COMMON-MODE VOLTAGE (V)
Figure 5. Input Offset Voltage Figure 8. Input Bias Current vs. Common-Mode Voltage Rev. F | Page 6 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION FUNCTIONAL DESCRIPTION Power Consumption Driving Large Capacitive Loads Slew Rate (Unity Gain Inverting vs. Noninverting) Input Overvoltage Protection No Phase Reversal THD Readings vs. Common-Mode Voltage Noise vs. Common-Mode Voltage Settling Time Output Current Capability Operating with Supplies Greater than ±13 V Input Offset Voltage Adjustment Programmable Gain Amplifier (PGA) High Speed Instrumentation Amplifier High Speed Filters Second-Order, Low-Pass Filter High Speed, Low Noise Differential Driver OUTLINE DIMENSIONS ORDERING GUIDE
