Datasheet AD8091, AD8092 (Analog Devices) - 9
DescriptionLow Cost, High Speed Rail-to-Rail Amplifiers
Pages / Page20 / 9 — AD8091/AD8092. –20. 0.10. VO = 2V p-p. ) 0.08. NTSC SUBSCRIBER (3.58MHz). …
RevisionC
File Format / SizePDF / 323 Kb
AD8091/AD8092. –20. 0.10. VO = 2V p-p. ) 0.08. NTSC SUBSCRIBER (3.58MHz). RL = 150Ω. VS = 3V, G = –1. –30. 0.06. RF = 2kΩ, RL = 100Ω. TI R (
AD8091/AD8092 –20 0.10 VO = 2V p-p ) 0.08 NTSC SUBSCRIBER (3.58MHz) RL = 150Ω VS = 3V, G = –1 –30 0.06 RF = 2kΩ, RL = 100Ω TI R (
AD8091/AD8092 –20 0.10 VO = 2V p-p ) 0.08 NTSC SUBSCRIBER (3.58MHz) RL = 150Ω VS = 3V, G = –1 L –30 % A 0.06 RF = 2kΩ, RL = 100Ω TI R ( Bc) 0.04 N d –40 VS = 5V, G = +2 E 0.02 R R RRO N ( F = 2kΩ, RL = 100Ω E E 0 IO V –50 S = 5V, G = +1 IFF IN –0.02 RT R R L = 100Ω D A V L = 1kΩ S = 5, G = +2 O G –0.04 T RF = 2kΩ, RL AS SHOWN S –60 –0.06 0 10 20 30 40 50 60 70 80 90 100 C DI NI –70 0.10 O rees) R 0.05 L = 1kΩ L –80 VS = 5V, G = +1 A eg 0 ARM RL = 2kΩ TI H N (DR –0.05 L –90 V E A S = 5V, G = +2 R O R R L = 150Ω F = 2kΩ, RL = 2kΩ E R –0.10 R TOT –100
1 1
IFF E –0.15
4 0
E VS = 5, G = +2
01
D
9-
–0.20
9-
R
85
85
–110
02
HAS –0.25
02
P 1 2 3 4 5 6 7 8 9 10 0 10 20 30 40 50 60 70 80 90 100 FUNDAMENTAL FREQUENCY (MHz) MODULATING RAMP LEVEL (IRE)
Figure 11. Total Harmonic Distortion Figure 14. Differential Gain and Phase Errors
–30 1000 VS = 5V –40 10MHz –50 ) Bc) –60 Hz (d 100 A IC n –70 N ( E O IS –80 5MHz ARM NO H E –90 T S R 1MHz 10 LTAG O –100 O W V –110 VS = 5V –120
2 5
R
01
L = 2kΩ
01 9-
G = +2
9- 85 85
–130
02
1
02
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 10 100 1k 10k 100k 1M 10M OUTPUT VOLTAGE (V p-p) FREQUENCY (Hz)
Figure 12. Worst Harmonic vs. Output Voltage Figure 15. Input Voltage Noise vs. Frequency
5.0 100 ) -p VS = 5V 4.5 VS = 5V G = –1 ) (V p 4.0 RF = 2kΩ RL = 2kΩ ) 0.5%
3.5 Hz D 10 A H p T 3.0 ( ( E G N IS 2.5 NO E SWI 2.0 NT G 1 1.5 LTA CURRE VO 1.0 T U P T 0.5
3 6 01
U
01 9-
O
9- 85 85
0
02
0.1
02
0.1 1 10 50 10 100 1k 10k 100k 1M 10M FREQUENCY (MHz) FREQUENCY (Hz)
Figure 13. Low Distortion Rail-to-Rail Output Swing Figure 16. Input Current Noise vs. Frequency Rev. C | Page 9 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION MAXIMUM POWER DISSIPATION TYPICAL PERFORMANCE CHARACTERISTICS LAYOUT, GROUNDING, AND BYPASSING CONSIDERATIONS POWER SUPPLY BYPASSING GROUNDING INPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING DRIVING CAPACITIVE LOADS OVERDRIVE RECOVERY ACTIVE FILTERS SYNC STRIPPER SINGLE-SUPPLY COMPOSITE VIDEO LINE DRIVER OUTLINE DIMENSIONS ORDERING GUIDE
