Datasheet AD8016 (Analog Devices) - 8
Description | Full Rate ADSL Line Driver With Powerdown |
Pages / Page | 21 / 8 — Data Sheet. AD8016. TYPICAL PERFORMANCE CHARACTERISTICS. VOUT = 100mV. … |
Revision | C |
File Format / Size | PDF / 517 Kb |
Data Sheet. AD8016. TYPICAL PERFORMANCE CHARACTERISTICS. VOUT = 100mV. –75dBc. DI B/. OLTS V. 10d. VIN = 20mV. TIME (100ns/DIV). 549.3
Data Sheet AD8016 TYPICAL PERFORMANCE CHARACTERISTICS VOUT = 100mV V –75dBc DI B/ OLTS V 10d VIN = 20mV
010
TIME (100ns/DIV) 549.3
004
550.3 551.3 552.3 553.3 554.3 555.3 556.3 557.3 558.3 559.3
01019-
FREQUENCY (kHz)
01019- Figure 6. Multitone Power Ratio; VS = ±12 V, 20.4 dBm Output Power into Figure 9. 100 mV Step Response; G = +5, VS = ±12 V, RL = 25 Ω, Single-Ended 100 Ω, Downstream
VOUT = 100mV VOUT = 4V OLTS OLTS V V VIN = 20mV VIN = 800mV
1 1 0 008
TIME (100ns/DIV) TIME (100ns/DIV)
01019- 01019- Figure 7. 100 mV Step Response; G = +5, VS = ±6 V, RL = 25 Ω, Single-Ended Figure 10. 4 V Step Response; G = +5, VS = ±12 V, RL = 25 Ω, Single-Ended
–30 R V F = 499Ω OUT = 5V G = +10 (0,0) –40 VOUT = 4V p-p –50 (0,1) ) c (1,0) dB –60 ( OLTS –70 V TION VIN = 800mV TOR IS –80 D PWDN1, PWDN0 = (1,1) –90 –100
009
TIME (100ns/DIV) –110
01019- 012
0.01 0.1 1 10 20 FREQUENCY (MHz)
01019- Figure 8. 4 V Step Response; G = +5, VS = ±6 V, RL = 25 Ω, Single-Ended Figure 11. Distortion vs. Frequency; Second Harmonic, VS = ±12 V, RL = 50 Ω, Differential Rev. C | Page 7 of 20 Document Outline Features Pin Configurations General Description Revision History Specifications Logic Inputs (CMOS Compatible Logic) Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuts Theory of Operation Power Supply and Decoupling Feedback Resistor Selection Bias Pin and PWDN Features Thermal Shutdown Applications Information Multitone Power Ratio (MTPR) Generating DMT Power Dissipation Thermal Enhancements and PCB Layout Thermal Testing Air Flow Test Conditions DUT Power Thermal Resistance PCB Dimensions of a Differential Driver Circuit Experimental Results Outline Dimensions Ordering Guide
