Datasheet OP162, OP262, OP462 (Analog Devices)
Description | 15 MHz Rail-to-Rail Operational Amplifiers |
Pages / Page | 20 / 1 — 15 MHz Rail-to-Rail. Operational Amplifiers. Data Sheet. OP162/. OP262/. … |
Revision | H |
File Format / Size | PDF / 476 Kb |
15 MHz Rail-to-Rail. Operational Amplifiers. Data Sheet. OP162/. OP262/. OP462. FEATURES. PIN CONFIGURATIONS. Wide bandwidth: 15 MHz
15 MHz Rail-to-Rail Operational Amplifiers Data Sheet OP162/ OP262/ OP462 FEATURES PIN CONFIGURATIONS Wide bandwidth: 15 MHz NULL 1 8 NULL Low offset voltage: 325 µV max –IN A 2 OP162 7 V+ Low noise: 9.5 nV/√Hz @ 1 kHz +IN A 3 6 TOP VIEW OUT A Single-supply operation: 2.7 V to 12 V V– (Not to Scale) 4 5 NC Rail-to-rail output swing NC = NO CONNECT
00288-001
Low TCV OS: 1 µV/°C typ High slew rate: 13 V/µs
Figure 1. 8-Lead Narrow-Body SOIC (S Suffix)
No phase inversion Unity-gain stable OUT A 1 8 V+ –IN A 2 OP262 7 OUT B APPLICATIONS TOP VIEW +IN A 3 6 –IN B (Not to Scale) Portable instrumentation V– 4 5 +IN B Sampling ADC amplifier
00288-004
Wireless LANs
Figure 2. 8-Lead TSSOP (RU Suffix) and 8-Lead Narrow-Body SOIC (S Suffix)
Direct access arrangement Office automation OUT A 1 14 OUT D –IN A 2 13 –IN D +IN A 3 OP462 12 +IN D GENERAL DESCRIPTION TOP VIEW V+ 4 11 V– (Not to Scale)
The OP162 (single), OP262 (dual), and OP462 (quad) rail-to-
+IN B 5 10 +IN C
rail 15 MHz amplifiers feature the extra speed new designs
–IN B 6 9 –IN C
require, with the benefits of precision and low power operation.
OUT B 7 8 OUT C
With their incredibly low offset voltage of 45 µV (typical) and 00288-006 low noise, they are perfectly suited for precision filter applica- Figure 3. 14-Lead Narrow-Body SOIC (S Suffix) and 14-Lead TSSOP (RU Suffix) tions and instrumentation. The low supply current of 500 µA (typical) is critical for portable or densely packed designs. In addition, the rail-to-rail output swing provides greater dynamic range and control than standard video amplifiers. These products operate from single supplies as low as 2.7 V to dual supplies of ±6 V. The fast settling times and wide output swings recommend them for buffers to sampling A/D converters. The output drive of 30 mA (sink and source) is needed for many audio and display applications; more output current can be supplied for limited durations. The OPx62 family is specified over the extended industrial temperature range (–40°C to +125°C). The single OP162 amplifiers are available in 8-lead SOIC package. The dual OP262 amplifiers are available in 8-lead SOIC and TSSOP packages. The quad OP462 amplifiers are available in 14-lead, narrow-body SOIC and TSSOP packages.
Rev. H Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Pin Configurations Revision History Specifications Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Applications Functional Description Offset Adjustment Rail-to-Rail Output Output Short-Circuit Protection Input Overvoltage Protection Output Phase Reversal Power Dissipation Unused Amplifiers Power-On Settling Time Capacitive Load Drive Total Harmonic Distortion and Crosstalk PCB Layout Considerations Applications Circuits Single-Supply Stereo Headphone Driver Instrumentation Amplifier Direct Access Arrangement Outline Dimensions Ordering Guide
