Datasheet OP162, OP262, OP462 (Analog Devices) - 6
Description15 MHz Rail-to-Rail Operational Amplifiers
Pages / Page20 / 6 — OP162/OP262/OP462. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 4. …
RevisionH
File Format / SizePDF / 476 Kb
OP162/OP262/OP462. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Min. Table 5. Package Type. θ 1. θJC. Unit. ESD CAUTION
OP162/OP262/OP462 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Min Table 5 Package Type θ 1 θJC Unit ESD CAUTION
link to page 6 link to page 6 link to page 6
OP162/OP262/OP462 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 4.
Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress
Parameter Min
rating only; functional operation of the device at these or any Supply Voltage ±6 V other conditions above those indicated in the operational Input Voltage1 ±6 V section of this specification is not implied. Exposure to absolute Differential Input Voltage2 ±0.6 V maximum rating conditions for extended periods may affect Internal Power Dissipation device reliability. SOIC (S) Observe Derating Curves TSSOP (RU) Observe Derating Curves
Table 5.
Output Short-Circuit Duration Observe Derating Curves
Package Type θ 1 JA θJC Unit
Storage Temperature Range –65°C to +150°C 8-Lead SOIC (S) 157 56 °C/W Operating Temperature Range –40°C to +125°C 8-Lead TSSOP (RU) 208 °C/W Junction Temperature Range –65°C to +150°C 14-Lead SOIC (S) 105 °C/W Lead Temperature Range 14-Lead TSSOP (RU) 148 °C/W (Soldering, 10 sec) 300°C 1 θJA is specified for the worst-case conditions, that is, θJA is specified for a 1 For supply voltages greater than 6 V, the input voltage is limited to less than device soldered in circuit board for SOIC, and TSSOP packages. or equal to the supply voltage. 2 For differential input voltages greater than 0.6 V, the input current should be
ESD CAUTION
limited to less than 5 mA to prevent degradation or destruction of the input devices. Rev. H | Page 6 of 20 Document Outline Features Applications General Description Pin Configurations Revision History Specifications Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Applications Functional Description Offset Adjustment Rail-to-Rail Output Output Short-Circuit Protection Input Overvoltage Protection Output Phase Reversal Power Dissipation Unused Amplifiers Power-On Settling Time Capacitive Load Drive Total Harmonic Distortion and Crosstalk PCB Layout Considerations Applications Circuits Single-Supply Stereo Headphone Driver Instrumentation Amplifier Direct Access Arrangement Outline Dimensions Ordering Guide
