Datasheet OP184, OP284, OP484 (Analog Devices) - 2
DescriptionSingle-Supply Rail-to-Rail Input/Output Operational Amplifier
Pages / Page24 / 2 — OP184/OP284/OP484. TABLE OF CONTENTS. REVISION HISTORY 4/11—Rev. I to Rev …
RevisionJ
File Format / SizePDF / 685 Kb
OP184/OP284/OP484. TABLE OF CONTENTS. REVISION HISTORY 4/11—Rev. I to Rev J. 4/06—Rev. C to Rev. D. 10/10—Rev. H to Rev I
OP184/OP284/OP484 TABLE OF CONTENTS REVISION HISTORY 4/11—Rev I to Rev J 4/06—Rev C to Rev D 10/10—Rev H to Rev I
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 3 link to page 6 link to page 6 link to page 6 link to page 7 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 15 link to page 16 link to page 16 link to page 17 link to page 17 link to page 18 link to page 18 link to page 19 link to page 20 link to page 21 link to page 23
Features .. 1 Output Phase Reversal ... 15 Applications ... 1 Designing Low Noise Circuits in Single-Supply Applications General Description ... 1 ... 15 Pin Configurations ... 1 Overdrive Recovery ... 16 Revision History ... 2 Single-Supply, 3 V Instrumentation Amplifier .. 16 Specifications ... 3 2.5 V Reference from a 3 V Supply .. 17 Electrical Characteristics ... 3 5 V Only, 12-Bit DAC Swings Rail-to-Rail ... 17 Absolute Maximum Ratings .. 6 High-Side Current Monitor .. 18 Thermal Resistance .. 6 Capacitive Load Drive Capability .. 18 ESD Caution .. 6 Low Dropout Regulator with Current Limiting ... 19 Typical Performance Characteristics ... 7 3 V, 50 Hz/60 Hz Active Notch Filter with False Ground ... 20 Applications Information .. 14 Outline Dimensions ... 21 Functional Description .. 14 Ordering Guide .. 23 Input Overvoltage Protection ... 14
REVISION HISTORY 4/11—Rev. I to Rev J 4/06—Rev. C to Rev. D
Change to Figure 27 ... 10 Changes to Table 1 ... 3 Changes to Table 2 ... 4
Changes to Table 3 ... 5 Change to Output Characteristics, Output Voltage High Deleted Reference to 1993 System Applications Guide .. 15 Parameter, Table 2 ... 3 Change to Output Characteristics, Output Voltage High
3/06—Rev. B to Rev. C
Parameter, Table 3 ... 4 Changes to Figure 1 Caption.. 1 Changes to Table 1 ... 3
7/10—Rev. G to Rev. H
Changes to Table 2 ... 4 Added Table 1 .. 1 Changes to Table 3 ... 5 Changes to Table 4 ... 6
2/09—Rev. F to Rev. G
Changes to Figure 5 through Figure 9 .. 7 Change to Large Signal Voltage Gain, Table 3 .. 5 Changes to Functional Description Section ... 14 Updated Outline Dimensions ... 21 Deleted SPICE Macro Model .. 21 Changes to Ordering Guide .. 22 Updated Outline Dimensions ... 21
9/08—Rev. E to Rev. F
Changes to Ordering Guide .. 22 Changes to General Description .. 1
9/02—Rev. A to Rev. B
Changes to Figure 4 .. 6 Changes to Pin Configurations ... 1 Changes to Low Dropout Regulator with Current Limiting .. 20 Changes to Specifications, Input Bias Current Maximum .. 2
7/08—Rev. D to Rev. E
Changes to Ordering Guide ... 5 Updated Outline Dimensions ... 19 Changes to Figure 1 .. 1 Changes to Figure 12 .. 8
6/02—Rev. 0 to Rev. A
Changes to Figure 36 and Figure 37 ... 12
10/96—Revision 0: Initial Version
Changes to Designing Low Noise Circuits in Single-Supply Applications Section ... 15 Updated Outline Dimensions ... 21 Changes to Ordering Guide .. 22 Rev. J | Page 2 of 24 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Functional Description Input Overvoltage Protection Output Phase Reversal Designing Low Noise Circuits in Single-Supply Applications Overdrive Recovery Single-Supply, 3 V Instrumentation Amplifier 2.5 V Reference from a 3 V Supply 5 V Only, 12-Bit DAC Swings Rail-to-Rail High-Side Current Monitor Capacitive Load Drive Capability Low Dropout Regulator with Current Limiting 3 V, 50 Hz/60 Hz Active Notch Filter with False Ground Outline Dimensions Ordering Guide
