link to page 6 OP184/OP284/OP484ABSOLUTE MAXIMUM RATINGSTable 5.THERMAL RESISTANCEParameterRating θ Supply Voltage ±18 V JA is specified for the worst-case conditions; that is, θJA is specified for a device in socket for PDIP. θ Input Voltage ±18 V JA is specified for a device soldered in the circuit board for SOIC packages. Differential Input Voltage1 ±0.6 V Output Short-Circuit Duration to GND Indefinite Table 6. Thermal Resistance Storage Temperature Range Package TypeθJAθJCUnit P-Suffix, S-Suffix Packages −65°C to +150°C 8-Lead PDIP (P-Suffix) 103 43 °C/W Operating Temperature Range 8-Lead SOIC (S-Suffix) 158 43 °C/W OP184/OP284/OP484E/OP484F −40°C to +125°C 14-Lead PDIP (P-Suffix) 83 39 °C/W Junction Temperature Range 14-Lead SOIC (S-Suffix) 92 27 °C/W P-Suffix, S-Suffix Packages −65°C to +150°C Lead Temperature 300°C (Soldering 60 sec) ESD CAUTION 1 For input voltages greater than 0.6 V, the input current should be limited to less than 5 mA to prevent degradation or destruction of the input devices. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute maximum ratings apply to both DICE and packaged parts, unless otherwise noted. VCCRB1R3R4QB6QB5RB3RB4R11TPQ12Q16Q17Q11JB1Q8QL1Q7QB9Q1Q3Q4Q2QB10–IN+INCC2Q10Q9OUTQL2Q5C OQ6C FFR6QB2CB1 N+Q18QB3M P+RB2QB4R7Q14Q15QB7Q13QB1QB8R1R2CC1R5R8R9R10 004 JB2VEE 00293- Figure 4. Simplified Schematic Rev. J | Page 6 of 24 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Functional Description Input Overvoltage Protection Output Phase Reversal Designing Low Noise Circuits in Single-Supply Applications Overdrive Recovery Single-Supply, 3 V Instrumentation Amplifier 2.5 V Reference from a 3 V Supply 5 V Only, 12-Bit DAC Swings Rail-to-Rail High-Side Current Monitor Capacitive Load Drive Capability Low Dropout Regulator with Current Limiting 3 V, 50 Hz/60 Hz Active Notch Filter with False Ground Outline Dimensions Ordering Guide
