Datasheet AD8005 (Analog Devices) - 2
Description270 MHz, 400µA Current Feedback Amplifier
Pages / Page17 / 2 — AD8005* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 416 Kb
AD8005* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8005* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• Universal Evaluation Board for Single High Speed • MT-034: Current Feedback (CFB) Op Amps Operational Amplifiers • MT-051: Current Feedback Op Amp Noise Considerations • MT-057: High Speed Current Feedback Op Amps
DOCUMENTATION
• MT-059: Compensating for the Effects of Input
Application Notes
Capacitance on VFB and CFB Op Amps Used in Current-to- • AN-253: Find Op Amp Noise with Spreadsheet Voltage Converters • AN-257: Careful Design Tames High Speed Op Amps • AN-356: User's Guide to Applying and Measuring
DESIGN RESOURCES
Operational Amplifier Specifications • AD8005 Material Declaration • AN-649: Using the Analog Devices Active Filter Design • PCN-PDN Information Tool • Quality And Reliability • AN-692: Universal Precision Op Amp Evaluation Board • Symbols and Footprints
Data Sheet
• AD8005: 270 MHz, 400 µA Current Feedback Amplifier
DISCUSSIONS
Data Sheet View all AD8005 EngineerZone Discussions.
User Guides
• UG-755: 8-Lead SOIC Amplifier Evaluation Board User
SAMPLE AND BUY
Guide Visit the product page to see pricing options. • UG-838: Evaluation Board for Single, High Speed Op Amps Offered in 5-Lead SOT-23 and 6-Lead SOT-23 Packages
TECHNICAL SUPPORT TOOLS AND SIMULATIONS
Submit a technical question or find your regional support number. • AD8005 SPICE Macro-Model
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications ±5 V Supplies +5 V Supply Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Typical Performance Characteristics Applications Driving Capicative Loads Single-Supply Level Shifter Single-Ended-to-Differential Conversion Layout Considerations Increasing Feedback Resistors Outline Dimensions Ordering Guide
