Datasheet AD8031, AD8032 (Analog Devices) - 7
Description2.7 V, 800 μA, 80 MHz Rail-to-Rail I/O Amplifiers
Pages / Page20 / 7 — Data Sheet. AD8031/AD8032. TYPICAL PERFORMANCE CHARACTERISTICS. 800. 600. …
RevisionG
File Format / SizePDF / 422 Kb
Data Sheet. AD8031/AD8032. TYPICAL PERFORMANCE CHARACTERISTICS. 800. 600. N = 250. N 70. 400. n (. N BI. I 60. 200. S = 10V. ART. URRE. S = 2.7V
Data Sheet AD8031/AD8032 TYPICAL PERFORMANCE CHARACTERISTICS 800 600 N = 250 N 70 400 n ( N BI I 60 200 S = 10V ART URRE S = 2.7V
Data Sheet AD8031/AD8032 TYPICAL PERFORMANCE CHARACTERISTICS 90 800 80 600 N = 250 N 70 A) 400 n ( N BI T I 60 N S 200 V 50 S = 10V ART URRE V V S = 2.7V S = 5V P 0 C F 40 AS R O BI –200 BE 30 UT –400 NUM 20 INP –600 10 0 –800
11
–5 –4 –3 –2 –1 0 1 2 3 4 5
08 0 0
0 1 2 3 4 5 6 7 8 9 10
6- 6-
V
05
OS (mV)
05
COMMON-MODE VOLTAGE (V)
01 01 Figure 8. Typical VOS Distribution @ VS = 5 V Figure 11. Input Bias Current vs. Common-Mode Voltage
2.5 0 VS = 5V –0.1 2.3 ) ) V V m m ( ( –0.2 E GE 2.1 G V A S = +5V LTA T L O –0.3 V VO T E 1.9 ET S S V –0.4 S = ±5V F F OFF O 1.7 –0.5 1.5
09
–0.6 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90
0 12 6-
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0
0 6-
TEMPERATURE (°C)
05 05 01
01 Figure 9. Input Offset Voltage vs. Temperature Figure 12. VOS vs. Common-Mode Voltage
1.00 1000 0.95 ±IS, VS = ±5V ) V 950 S = 5V A 0.90 µ ( 900 0.85 IER IF A) PL 850 (µ 0.80 +I M S, VS = +5V AS /A 0.75 T BI 800 T EN U R 0.70 R INP U 750 0.65 Y C +IS, VS = +2.7V 700 0.60 PPL SU 650 0.55 0.50
10
600
3
0 01 6-
6-
TEMPERATURE (°C)
05
TEMPERATURE (°C)
05 01 01 Figure 10. Input Bias Current vs. Temperature Figure 13. Supply Current vs. Temperature Rev. G | Page 7 of 20 Document Outline Features Applications General Description Connection Diagrams Table of Contents Revision History Specifications +2.7 V Supply +5 V Supply ±5 V Supply Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Typical Performance Characteristics Theory of Operation Input Stage Operation Overdriving the Input Stage Output Stage, Open-Loop Gain and Distortion vs. Clearance from Power Supply Output Overdrive Recovery Driving Capacitive Loads Applications A 2 MHz Single-Supply, Biquad Band-Pass Filter High Performance, Single-Supply Line Driver Outline Dimensions Ordering Guide
