Datasheet AD823 (Analog Devices) - 2
Description16 MHz, Rail-to-Rail FET Input Dual Amplifier
Pages / Page21 / 2 — AD823* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionE
File Format / SizePDF / 453 Kb
AD823* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD823* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• Universal Evaluation Board for Dual High Speed • MT-032: Ideal Voltage Feedback (VFB) Op Amp Operational Amplifiers • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • MT-047: Op Amp Noise
DOCUMENTATION
• MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
Application Notes
Noise, and Equivalent Noise Bandwidth • AN-108: JFET-Input Amps are Unrivaled for Speed and • MT-049: Op Amp Total Output Noise Calculations for Accuracy Single-Pole System • AN-253: Find Op Amp Noise with Spreadsheet • MT-050: Op Amp Total Output Noise Calculations for • AN-257: Careful Design Tames High Speed Op Amps Second-Order System • AN-402: Replacing Output Clamping Op Amps with Input • MT-052: Op Amp Noise Figure: Don't Be Misled Clamping Amps • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease SFDR, MTPR Design Constraints in Low Voltage High Speed Systems • MT-056: High Speed Voltage Feedback Op Amps • AN-581: Biasing and Decoupling Op Amps in Single • MT-058: Effects of Feedback Capacitance on VFB and CFB Supply Applications Op Amps • AN-649: Using the Analog Devices Active Filter Design • MT-060: Choosing Between Voltage Feedback and Tool Current Feedback Op Amps
Data Sheet
• AD823: Dual, 16 MHz, Rail-to-Rail FET Input Amplifier Data
DESIGN RESOURCES
Sheet • AD823 Material Declaration
User Guides
• PCN-PDN Information • UG-128: Universal Evaluation Board for Dual High Speed • Quality And Reliability Op Amps in SOIC Packages • Symbols and Footprints
TOOLS AND SIMULATIONS DISCUSSIONS
• Analog Filter Wizard View all AD823 EngineerZone Discussions. • Analog Photodiode Wizard • Power Dissipation vs Die Temp
SAMPLE AND BUY
• VRMS/dBm/dBu/dBV calculators Visit the product page to see pricing options. • AD823 SPICE Macro-Model • AD823A SPICE Macro-Model
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Applications Connection Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Theory of Operation Output Impedance Application Notes Input Characteristics Output Characteristics A/D Driver 3 V, Single-Supply Stereo Headphone Driver Second-Order Low-Pass Filter Single-Supply Half-Wave and Full-Wave Rectifiers Outline Dimensions Ordering Guide
