Datasheet AD823 (Analog Devices) - 10
Description | 16 MHz, Rail-to-Rail FET Input Dual Amplifier |
Pages / Page | 21 / 10 — Data Sheet. AD823. L = 20pF. S = ±15V. RL = 2kΩ G = +1. S = +5V. d N (. … |
Revision | E |
File Format / Size | PDF / 453 Kb |
Data Sheet. AD823. L = 20pF. S = ±15V. RL = 2kΩ G = +1. S = +5V. d N (. AI G P. -LOO. RR (. +27°C. –55°C. LOS. +125°C. C –2
Data Sheet AD823 5 90 C V L = 20pF S = ±15V 4 RL = 2kΩ G = +1 80 +V B) 3 S = +5V d N ( 2 70 AI G P 1 B) 60 d 0 -LOO RR ( D +27°C –55°C E 50 –1 CM LOS +125°C C –2 40 –3 30 –4 –5 20 0.30 3.27 6.24 9.21 12.18 15.15 18.12 21.09 24.06 27.03 30.00
017
10 100 1k 10k 100k 1M 10M
020
FREQUENCY (MHz)
00901-
FREQUENCY (Hz)
00901- Figure 17. Closed-Loop Gain vs. Frequency Figure 20. Common-Mode Rejection Ratio vs. Frequency
100 10 +V +VS = +5V S = +5V GAIN = +1 ) Ω 10 E (V) ( G A 1 LT ANCE O T V V IS S – VOH S 1 25°C E TION A T R U UR T TP 0.1 A VOL OU 0.1 T S 25°C U TP OU 0.01 0.01 100 1k 10k 100k 1M 10M
018
0.1 1 10 100
021
FREQUENCY (Hz) LOAD CURRENT (mA)
00901- 00901- Figure 18. Output Resistance vs. Frequency, +VS = +5 V, Gain = +1 Figure 21. Output Saturation Voltage vs. Load Current
10 10 VS = ±15V (V) N C 8 L = 20pF W 1% 0.1% 0.01% +125°C HO 8 S 6 O V mA) +25°C T 4 ( V NT 0 2 6 –55°C OM 0 FR CURRE NT IZE –2 4 S CE P S –4 E TE 1% 0.1% 0.01% UI T S Q –6 2 U TP –8 OU –10 0 100 200 300 400 500 600 700
022 019
0 5 10 15 20 SETTLING TIME (ns) SUPPLY VOLTAGE (±V)
00901- 00901- Figure 19. Output Step Size vs. Settling Time (Inverter) Figure 22. Quiescent Current vs. Supply Voltage Rev. E | Page 9 of 20 Document Outline Features Applications Connection Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Theory of Operation Output Impedance Application Notes Input Characteristics Output Characteristics A/D Driver 3 V, Single-Supply Stereo Headphone Driver Second-Order Low-Pass Filter Single-Supply Half-Wave and Full-Wave Rectifiers Outline Dimensions Ordering Guide
