Datasheet AD8041 (Analog Devices) - 7
Description160 MHz Rail-to-Rail Amplifier with Disable
Pages / Page18 / 7 — AD8041. ABSOLUTE MAXIMUM RATINGS1. 2.0. 8-LEAD PDIP PACKAGE. TJ = 150. …
RevisionB
File Format / SizePDF / 313 Kb
AD8041. ABSOLUTE MAXIMUM RATINGS1. 2.0. 8-LEAD PDIP PACKAGE. TJ = 150. 1.5. 1.0. 8-LEAD SOIC PACKAGE. 0.5. MAXIMUM POWER DISSIPATION (W)
AD8041 ABSOLUTE MAXIMUM RATINGS1 2.0 8-LEAD PDIP PACKAGE TJ = 150 1.5 1.0 8-LEAD SOIC PACKAGE 0.5 MAXIMUM POWER DISSIPATION (W)
AD8041
the stresses exerted on the die by the package. Exceeding a Supply Voltage .. 12.6 V junction temperature of 175°C for an extended period can result Internal Power Dissipation2 in device failure. PDIP Package (N) .. 1.3 W While the AD8041 is internally short-circuit protected, this may SOIC Package (R) .. 0.9 W not be sufficient to guarantee that the maximum junction tem- Input Voltage (Common Mode) .. ± VS perature (150°C) is not exceeded under all conditions. To Differential Input Voltage ... ± 3.4 V ensure proper operation, it is necessary to observe the maximum Output Short-Circuit Duration power derating curves. .. Observe Power Derating Curves Storage Temperature Range N, R .. –65°C to +125°C
2.0
Operating Temperature Range (A Grade) ... –40°C to +85°C
8-LEAD PDIP PACKAGE
Lead Temperature Range (Soldering 10 sec) ... 300°C
TJ = 150
C
NOTES
1.5
1Stresses above those listed under Absolute Maximum Ratings may cause perma- nent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating
1.0
conditions for extended periods may affect device reliability. 2Specification is for the device in free air: 8-Lead PDIP Package: θJA = 90°C/W.
8-LEAD SOIC PACKAGE
8-Lead SOIC Package: θ
0.5
JA = 155°C/W.
MAXIMUM POWER DISSIPATION (W) MAXIMUM POWER DISSIPATION
The maximum power that can be safely dissipated by the
0
AD8041 is limited by the associated rise in junction temperature.
–50 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 AMBIENT TEMPERATURE (
C)
The maximum safe junction temperature for plastic encapsulated devices is determined by the glass transition temperature of the Figure 3. Maximum Power Dissipation vs. Temperature plastic, approximately 150°C. Exceeding this limit temporarily may cause a shift in parametric performance due to a change in
ORDERING GUIDE Temperature Package Package Model Range Description Options
AD8041AN –40°C to +85°C 8-Lead PDIP N-8 AD8041AR –40°C to +85°C 8-Lead Plastic SOIC R-8 AD8041AR-REEL –40°C to +85°C 13" Tape and Reel R-8 AD8041AR-REEL7 –40°C to +85°C 7" Tape and Reel R-8 AD8041ARZ-REEL1 –40°C to +85°C 13" Tape and Reel R-8 5962-9683901MPA2 –55°C to +125°C 8-Lead CERDIP Q-8 NOTES 1The Z indicates a lead-free product. 2Refer to official DSCC drawing for tested specifications.
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although the AD8041 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. REV. B –5– Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONNECTION DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ORDERING GUIDE Typical Performance Characteristics Overdrive Recovery Circuit Description Output Impedance Disable Operation Single-Supply A/D Conversion APPLICATIONS RGB Buffer Single-Supply Composite Video Line Driver Sync Stripper Layout Considerations OUTLINE DIMENSIONS Revision History
