Datasheet OP113, OP213, OP413 (Analog Devices) - 5
DescriptionLow Noise, Low Drift Single-Supply Operational Amplifiers
Pages / Page24 / 5 — OP113/OP213/OP413. E Grade. F Grade. Parameter. Symbol. Conditions. Min. …
RevisionF
File Format / SizePDF / 491 Kb
OP113/OP213/OP413. E Grade. F Grade. Parameter. Symbol. Conditions. Min. Typ. Max. Min Typ. Unit
OP113/OP213/OP413 E Grade F Grade Parameter Symbol Conditions Min Typ Max Min Typ Unit
OP113/OP213/OP413 E Grade F Grade Parameter Symbol Conditions Min Typ Max Min Typ Max Unit
OUTPUT CHARACTERISTICS Output Voltage Swing High VOH RL = 600 kΩ 4.0 4.0 V RL = 100 kΩ, −40°C ≤ TA ≤ +85°C 4.1 4.1 V RL = 600 Ω, −40°C ≤ TA ≤ +85°C 3.9 3.9 V Output Voltage Swing Low VOL RL = 600 Ω, −40°C ≤ TA ≤ +85°C 8 8 mV RL = 100 kΩ, −40°C ≤ TA ≤ +85°C 8 8 mV Short-Circuit Limit ISC ±30 ±30 mA POWER SUPPLY Supply Current ISY VOUT = 2.0 V, no load 1.6 2.7 2.7 mA ISY –40°C ≤ TA ≤ +85°C 3.0 3.0 mA AUDIO PERFORMANCE THD + Noise VOUT = 0 dBu, f = 1 kHz 0.001 0.001 % Voltage Noise Density en f = 10 Hz 9 9 nV/√Hz f = 1 kHz 4.7 4.7 nV/√Hz Current Noise Density in f = 1 kHz 0.45 0.45 pA/√Hz Voltage Noise en p-p 0.1 Hz to 10 Hz 120 120 nV p-p DYNAMIC PERFORMANCE Slew Rate SR RL = 2 kΩ 0.6 0.9 0.6 V/μs Gain Bandwidth Product GBP 3.5 3.5 MHz Settling Time tS to 0.01%, 2 V step 5.8 5.8 μs 1 Long-term offset voltage is guaranteed by a 1000 hour life test performed on three independent lots at 125°C, with an LTPD of 1.3. 2 Guaranteed specifications, based on characterization data. Rev. F | Page 5 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS PHASE REVERSAL OP113 OFFSET ADJUST APPLICATION CIRCUITS A HIGH PRECISION INDUSTRIAL LOAD-CELL SCALE AMPLIFIER A LOW VOLTAGE, SINGLE SUPPLY STRAIN GAGE AMPLIFIER A HIGH ACCURACY LINEARIZED RTD THERMOMETER AMPLIFIER A HIGH ACCURACY THERMOCOUPLE AMPLIFIER AN ULTRALOW NOISE, SINGLE SUPPLY INSTRUMENTATION AMPLIFIER SUPPLY SPLITTER CIRCUIT LOW NOISE VOLTAGE REFERENCE 5 V ONLY STEREO DAC FOR MULTIMEDIA LOW VOLTAGE HEADPHONE AMPLIFIERS LOW NOISE MICROPHONE AMPLIFIER FOR MULTIMEDIA PRECISION VOLTAGE COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
