Datasheet AD828 (Analog Devices) - 8
DescriptionDual, Low Power Video Op Amp
Pages / Page13 / 8 — AD828. 1pF. 0.1dB. FLATNESS. 15V 40MHz. 15V 50MHz. 5V 43MHz. OUT. 5V …
RevisionC
File Format / SizePDF / 488 Kb
AD828. 1pF. 0.1dB. FLATNESS. 15V 40MHz. 15V 50MHz. 5V 43MHz. OUT. 5V 25MHz. +5V. 18MHz. 19MHz. VIN. 150. VS =. 15V. GAIN – dB –2. GAIN – dB –1. VS = +5V. –10
AD828 1pF 0.1dB FLATNESS 15V 40MHz 15V 50MHz 5V 43MHz OUT 5V 25MHz +5V 18MHz 19MHz VIN 150 VS = 15V GAIN – dB –2 GAIN – dB –1 VS = +5V –10
AD828 10 5 1pF 1pF 0.1dB 8 4 0.1dB VS FLATNESS V FLATNESS S 15V 40MHz 1k 6 1k 1k 1k 3 15V 50MHz V V 5V 43MHz OUT OUT V 5V 25MHz IN AD828 4 AD828 +5V 18MHz 2 +5V 19MHz VIN 150 150 2 VS = 15V 1 VS = 15V 0 0 GAIN – dB –2 GAIN – dB –1 VS = +5V –4 –2 VS = 5V VS = 5V –6 –3 VS = +5V –8 –4 –10 –5 100k 1M 10M 100M 100k 1M 10M 100M FREQUENCY – Hz FREQUENCY – Hz
TPC 19. Closed-Loop Gain vs. Frequency TPC 22. Closed-Loop Gain vs. Frequency, G = –1
0.03 1.0 0.8 0.02 0.6 DIFF GAIN 0.4 0.07 0.01 0.2 VS = 15V 0 DIFFERENTIAL GAIN – Percent 0.06 GAIN – dB –0.2 VS = 5V –0.4 DIFF PHASE 0.05 –0.6 VS = 5V –0.8 0.04 –1.0 DIFFERENTIAL PHASE – Degrees 5 10 15 100k 1M 10M 100M SUPPLY VOLTAGE – V FREQUENCY – Hz
TPC 20. Differential Gain and Phase vs. Supply Voltage TPC 23. Gain Flatness Matching vs. Supply, G = +2
–30 5V –40 0.1 F VOUT –50 1 F 3 5 –60 8 1/2 1/2 V 1 IN AD828 7 AD828 –70 RL = 150 2 4 6 –80 CROSSTALK – dB 0.1 F R RL –90 R L L = 1k 1 F –100 5V –110 10k 100k 1M 10M 100M USE GROUND PLANE FREQUENCY – Hz PINOUT SHOWN IS FOR MINI-DIP PACKAGE
TPC 21. Crosstalk vs. Frequency TPC 24. Crosstalk Test Circuit REV. C –7–
