Datasheet AD817 (Analog Devices) - 6
DescriptionHigh Speed, Low Power Wide Supply Range Amplifier
Pages / Page14 / 6 — AD817–Typical Characteristics. 8.0. Volts 15. 7.5. +VCM. +85. +25. 7.0. …
RevisionB
File Format / SizePDF / 252 Kb
AD817–Typical Characteristics. 8.0. Volts 15. 7.5. +VCM. +85. +25. 7.0. -40. 6.5. INPUT COMMON-MODE RANGE –. QUIESCENT SUPPLY CURRENT – mA. 6.0
AD817–Typical Characteristics 8.0 Volts 15 7.5 +VCM +85 +25 7.0 -40 6.5 INPUT COMMON-MODE RANGE – QUIESCENT SUPPLY CURRENT – mA 6.0
AD817–Typical Characteristics 20 8.0
C +25
C 10 7.0 –V -40
C CM 5 6.5 INPUT COMMON-MODE RANGE – QUIESCENT SUPPLY CURRENT – mA 0 6.0 0 5 10 15 20 0 5 10 15 20 SUPPLY VOLTAGE –
Volts SUPPLY VOLTAGE –
Volts
Figure 1. Common-Mode Voltage Range vs. Supply Figure 4. Quiescent Supply Current vs. Supply Voltage for Various Temperatures
20 400
Volts 15 350
µ
s R = 500
L 10 300 R = 150
L SLEW RATE – V/ 5 250 OUTPUT VOLTAGE SWING – 0 200 0 5 10 15 20 0 5 10 15 20 SUPPLY VOLTAGE –
Volts
Figure 2. Output Voltage Swing vs. Supply Figure 5. Slew Rate vs. Supply Voltage
30 100 25 10 V =
15V S 20 15 1 10 0.1 V =
5V S 5 OUTPUT VOLTAGE SWING – Volts p-p CLOSED-LOOP OUTPUT IMPEDANCE – Ohms 0 0.01 10 100 1k 10k 1k 10k 100k 1M 10M 100M LOAD RESISTANCE –
FREQUENCY – Hz
Figure 3. Output Voltage Swing vs. Load Resistance Figure 6. Closed-Loop Output Impedance vs. Frequency –4– REV. B
