Datasheet AD817 (Analog Devices) - 9
Description | High Speed, Low Power Wide Supply Range Amplifier |
Pages / Page | 14 / 9 — AD817. 0.05. DIFF GAIN. 3.3. 0.04. +VS. 0.01. 0.1. 0.03. TEKTRONIX. VOUT. … |
Revision | B |
File Format / Size | PDF / 252 Kb |
AD817. 0.05. DIFF GAIN. 3.3. 0.04. +VS. 0.01. 0.1. 0.03. TEKTRONIX. VOUT. P6201 FET. 7A24. DIFFERENTIAL GAIN – Percent. 0.08. PULSE (LS). 100. PROBE
AD817 0.05 1k
Ω
DIFF GAIN 3.3
µ
F 0.04 +VS 0.01
µ
F 0.1 0.03 7 2 TEKTRONIX TEKTRONIX HP VOUT P6201 FET 7A24 DIFFERENTIAL GAIN – Percent AD817 6 0.08 PULSE (LS) V 100
Ω
IN PROBE PREAMP OR FUNCTION DIFF PHASE 3 (SS) 4 0.01
µ
F GENERATOR 50
Ω
0.06 RL 3.3
µ
F –VS DIFFERENTIAL PHASE – Degrees 0.04
5
10
15 SUPPLY VOLTAGE – Volts
Figure 19. Differential Gain and Phase vs. Figure 22. Noninverting Amplifier Connection Supply Voltage
5 4 0.1dB 5V 50ns 1k
Ω
V C FLATNESS S C 1k
Ω
3 V V
15V 3pF 100 IN OUT 16MHz CC
5V 4pF 14MHz 90 2 +5V 6pF 12MHz B 1 d V =
15V S – 0 GAIN –1 –2 V =
5V S 10 0% –3 V = +5V S –4 5V –5 100k 1M 10M 100M FREQUENCY – Hz
Figure 20. Closed-Loop Gain vs. Frequency, Figure 23. Noninverting Large Signal Pulse Gain = –1 Response, RL = 1 kΩ
5 200mV 20ns 4 0.1dB 1k
Ω
V FLATNESS S 3
15V 70MHz 100 VOUT
5V 26MHz 90 V 2 IN 150
Ω
+5V 17MHz B 1 V =
15V S d – 0 GAIN –1 V =
5V S –2 10 0% –3 V = +5V S –4 200mV –5 100k 1M 10M 100M FREQUENCY – Hz
Figure 21. Closed-Loop Gain vs. Frequency, Figure 24. Noninverting Small Signal Pulse Gain = +1 Response, RL = 1 kΩ REV. B –7–
