Dual/Quad, Low Power, High Speed JFET Operational Amplifiers
Pages / Page
16 /6 — OP282/OP482. Data Sheet. 1000. S = ±15V. A = 25°C. L = 10kΩ. VOH. √Hz V/. …
Revision
I
PDF / 318 Kb
OP282/OP482. Data Sheet. 1000. S = ±15V. A = 25°C. L = 10kΩ. VOH. √Hz V/. (V). 100. SI EN. E SW G A. ISE D. T V. E N. G A. TP –10. –15. –20. 10k. ±10. ±15. ±20
OP282/OP482Data Sheet100020VTS = ±15VA = 25°CTRA = 25°CL = 10kΩ15)VOH√Hz V/(V)10(nGY100INT5SI ENE SW G A0ISE DLTOO–5T VE N10UG ATP –10LTOUVVOOL 1 1 –15 0 014 1 00301- –20 00301- 101001k10k0±5±10±15±20FREQUENCY (Hz)SUPPLY VOLTAGE (V) Figure 12. OP282 Voltage Noise Density vs. Frequency Figure 15. OP282 Output Voltage Swing vs. Supply Voltage 10001000VS = ±15VVS = ±15VTA = 25°CTA = 25°C100100A))pΩ((ANTVCL = 100DANCE10E10CURREP MASIAVCL = 10BIUT PUT1UT1INPOAVCL = 1 012 015 0.1 00301- 0.1 00301- –15–10–50510151001k10k100k1MCOMMON-MODE VOLTAGE (V)FREQUENCY (Hz) Figure 13. OP282 Input Bias Current vs. Common-Mode Voltage Figure 16. OP282 Closed-Loop Output Impedance vs. Frequency 480480TA = 25°C475475A)A)µ 470µ470((NTNT465465CURRECURREYYLLPP 460PP460SUSU455455 013 016 450 00301- 450 00301- 0±5±10±15±20–50–250255075100125SUPPLY VOLTAGE (V)TEMPERATURE (°C) Figure 14. OP282 Supply Current vs. Supply Voltage Figure 17. OP282 Supply Current vs. Temperature Rev. I | Page 6 of 16 Document Outline Features Applications General Description Pin Connections Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information High-Side Signal Conditioning Phase Inversion Active Filters Programmable State Variable Filter Outline Dimensions Ordering Guide
