Datasheet OP282, OP482 (Analog Devices) - 5
Description | Dual/Quad, Low Power, High Speed JFET Operational Amplifiers |
Pages / Page | 16 / 5 — Data Sheet. OP282/OP482. TYPICAL PERFORMANCE CHARACTERISTICS. 180. VS = … |
Revision | I |
File Format / Size | PDF / 318 Kb |
Data Sheet. OP282/OP482. TYPICAL PERFORMANCE CHARACTERISTICS. 180. VS = ±15V. TA = 25°C. 135. AVCL = 100. N (. rees). VCL = 10. Deg. -LOO. HAS
Data Sheet OP282/OP482 TYPICAL PERFORMANCE CHARACTERISTICS 80 180 70 VS = ±15V VS = ±15V TA = 25°C 60 TA = 25°C 60 135 50 AVCL = 100 B) 40 B) d d 40 90 N ( N ( 30 AI AI rees) A G VCL = 10 G 20 45 P 20 P Deg O ( O E -LOO 10 -L D 0 0 HAS E AVCL = 1 P PEN 0 O LOS C –10 –20 –45 –20
008
–40 –90 –30
00301- 005
1k 10k 100k 1M 10M 1k 10k 100k 1M 10M FREQUENCY (Hz)
00301-
FREQUENCY (Hz)
Figure 6. OP282 Open-Loop Gain and Phase vs. Frequency Figure 9. OP282 Closed-Loop Gain vs. Frequency
45 30 VS = ±15V VS = ±15V RL = 10kΩ 40 RL = 10kΩ C 25 L = 50pF 35 –SR ) /mV 30 20 V s) µ N ( AI 25 E (V/ G T 15 P A O 20 R O -L EW 15 10 SL PEN +SR O 10 5 5
006 009
0
00301-
0
00301-
–75 –50 –25 0 25 50 75 100 125 –75 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C)
Figure 7. OP282 Open-Loop Gain vs. Temperature Figure 10. OP282 Slew Rate vs. Temperature
80 1000 V V S = ±15V S = ±15V R V L = 2kΩ CM = 0V 70 VIN = 100mV p-p AVCL = 1 60 TA = 25°C 100 A) p ) +OS ( 50 NT (% T O –OS O 40 10 SH CURRE AS VER 30 BI O UT 20 1 INP 10
007 010
0
00301-
0.1
00301-
0 100 200 300 400 500 –75 –50 –25 0 25 50 75 100 125 LOAD CAPACITANCE (pF) TEMPERATURE (°C)
Figure 8. OP282 Small-Signal Overshoot vs. Load Capacitance Figure 11. OP282 Input Bias Current vs. Temperature Rev. I | Page 5 of 16 Document Outline Features Applications General Description Pin Connections Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information High-Side Signal Conditioning Phase Inversion Active Filters Programmable State Variable Filter Outline Dimensions Ordering Guide
