Datasheet AD841 (Analog Devices) - 5
DescriptionWideband, Unity-Gain Stable, Fast Settling Op Amp
Pages / Page17 / 5 — AD841. Data Sheet. Test Conditions/. AD841J. AD841K. AD841S1. Parameter. …
RevisionC
File Format / SizePDF / 380 Kb
AD841. Data Sheet. Test Conditions/. AD841J. AD841K. AD841S1. Parameter. Comments. Min Typ. Max Min Typ. Max. Unit
AD841 Data Sheet Test Conditions/ AD841J AD841K AD841S1 Parameter Comments Min Typ Max Min Typ Max Unit
link to page 10 link to page 10 link to page 5 link to page 5
AD841 Data Sheet Test Conditions/ AD841J AD841K AD841S1 Parameter Comments Min Typ Max Min Typ Max Min Typ Max Unit
TEMPERATURE RANGE Rated Performance5 0 70 0 70 −55 +125 °C 1 Standard military drawing available: 5962-89641012A – (SE/883B). 2 Input offset voltage specifications are guaranteed after 5 minutes at TA = 25°C. 3 Full power bandwidth = slew rate/2 π VPEAK. 4 Refer to Figure 22 to Figure 24. 5 S grade TMIN – TMAX specifications are tested with automatic test equipment at TA = −55°C and TA = +125°C. Rev. C | Page 4 of 16 Document Outline Features Applications Connection Diagrams General Description Product Highlights Revision History Specifications Absolute Maximum Ratings Thermal Characteristics ESD Caution Typical Performance Characteristics Theory of Operation Offset Nulling Input Considerations AD841 Settling Time Grounding and Bypassing Capacitive Load Driving Ability Terminated Line Driver Overdrive Recovery Outline Dimensions Ordering Guide
