Datasheet OP290 (Analog Devices) - 4
DescriptionLow Voltage Dual Precision, Micropower Op Amp
Pages / Page13 / 4 — OP290. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. OP290G. …
RevisionC
File Format / SizePDF / 268 Kb
OP290. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. OP290G. Parameter. Symbol Conditions. Min. Typ. Max. Unit
OP290 SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 1 OP290G Parameter Symbol Conditions Min Typ Max Unit
link to page 4 link to page 4 link to page 4
VS = ±1.5 V to ±15 V, TA = 25°C, unless otherwise noted.
Table 1. OP290G Parameter Symbol Conditions Min Typ Max Unit
INPUT OFFSET VOLTAGE V 125 500 μV OS INPUT OFFSET CURRENT I V = 0 V 0.1 5 nA OS CM INPUT BIAS CURRENT I V = 0 V 4.0 25 nA B CM LARGE-SIGNAL VOLTAGE GAIN A V = ±15 V, V = ±10 V VO S O R = 100 kΩ 400 600 V/mV L R = 10 kΩ 200 400 V/mV L R = 2 kΩ 100 200 V/mV L V+ = 5 V, V− = 0 V, 1 V < V < 4 V O R = 100 kΩ 100 250 V/mV L R = 10 kΩ 70 140 V/mV L INPUT VOLTAGE RANGE1 IVR V+ = 5 V, V − = 0 V 0/4 V V = ±5 V −5/+3.5 V S OUTPUT VOLTAGE SWING V V = ±5 V O S R = 10 kΩ ±13.5 ±14.2 V L R = 2 kΩ ±10.5 ±11.5 V L V , V V+ = 5 V, V− = 0 V 4.0 4.2 V OH OL R = 10 kΩ 10 50 μV L COMMON-MODE REJECTION CMR V+ = 5 V, V− = 0 V, 0 V < V < 4 V 80 100 dB CM V = ±15 V, −15 V < V < +13.5 V 90 120 dB S CM POWER SUPPLY REJECTION RATIO PSRR 3.2 10 μV/V SUPPLY CURRENT (ALL AMPLIFIERS) I V = ±1.5 V 19 30 μA SY S V = ±15 V 25 40 μA S CAPACITIVE LOAD STABILITY A = +1, no oscillations 650 pF V INPUT NOISE VOLTAGE1 e p-p f = 0.1 Hz to 10 Hz, V = ±15 V 3 μV p-p n O S INPUT RESISTANCE DIFFERENTIAL MODE R V = ±15 V 30 MΩ IN S INPUT RESISTANCE COMMON MODE R V = ±15 V 20 GΩ INCM S SLEW RATE SR A = +1, V = ±15 V 5 12 V/ms V S GAIN BANDWIDTH PRODUCT GBWP V = ±15 V 20 kHz S CHANNEL SEPARATION2 CS f = 10 Hz, V = 20 V p-p, V = ±15 V 120 150 dB O O S 1 Guaranteed by CMR test. 2 Guaranteed but not 100% tested. Rev. C | Page 3 of 12 Document Outline Features Pin Connections General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Theory of Operation Battery-Powered Applications Input Voltage Protection Single-Supply Output Voltage Range Applications Information Temperature to 4 mA to 20 mA Transmitter Variable Slew Rate Filter Low Overhead Voltage Reference Outline Dimensions Ordering Guide
