17 /10 — Data Sheet. OP07. 120. 100. A = 25°C. S = ±15V. TA = 25°C. 110. OP07C. dB …
Revision
G
PDF / 254 Kb
Data Sheet. OP07. 120. 100. A = 25°C. S = ±15V. TA = 25°C. 110. OP07C. dB (. RR ( S. -LOOP. D E. LOS C. –20. 0.1. 10k. 100k. 10M. FREQUENCY (Hz). 1000. VS = ±15V
Data SheetOP07120100TVA = 25°CS = ±15VTA = 25°C11080OP07C)100dB (60INB)90dGA40RR ( S80-LOOPPD E2070LOS C06050–200.11101001k10k 015 101001k10k100k1M10M 018 FREQUENCY (Hz)FREQUENCY (Hz) 00316- 00316- Figure 15. PSRR vs. Frequency Figure 18. Closed-Loop Frequency Response for Various Gain Configurations 100028VS = ±15VTA = 25°CTA = 25°C24800V)E (V) D20mU(V/IT600IN A16MPL AP GKO O12400-L-PEA OPEN-T8KO200PEA4000±5±10±15±20 016 1k10k100k1M 019 POWER SUPPLY VOLTAGE (V)FREQUENCY (Hz) 00316- 00316- Figure 16. Open-Loop Gain vs. Power Supply Voltage Figure 19. Maximum Output Swing vs. Frequency 12020VS = ±15VVTS = ±15VA = 25°CV100IN = ±10mVTA = 25°C80)15POSITIVE SWINGdB(V)(T60INPUNEGATIVE SWINGTGAU4010M O-LOOP N20MUEXIOPMA05–20–4000.11101001k10k100k1M10M 017 1001k10k 020 FREQUENCY (Hz)LOAD RESISTANCE TO GROUND (Ω) 00316- 00316- Figure 17. Open-Loop Frequency Response Figure 20. Maximum Output Voltage vs. Load Resistance Rev. G | Page 9 of 16 Document Outline Features Applications General Description Pin Configuration Revision History Specifications OP07E Electrical Characteristics OP07C Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Typical Applications Applications Information Outline Dimensions Ordering Guide
