Datasheet OP07 (Analog Devices) - 8 Manufacturer Analog Devices Description Ultralow Offset Voltage Op Amp Pages / Page 17 / 8 — Data Sheet. OP07. TYPICAL PERFORMANCE CHARACTERISTICS. 1000. 1.0. S = … Revision G File Format / Size PDF / 254 Kb Document Language English
Data Sheet. OP07. TYPICAL PERFORMANCE CHARACTERISTICS. 1000. 1.0. S = ±15V. 900. TA = 25°C. 800. 0.8. 700. (V/. D T. 600. 0.6. RRE. 500. P G. O O. 400. 0.4. R RE
Model Line for this Datasheet Text Version of Document Data Sheet OP07 TYPICAL PERFORMANCE CHARACTERISTICS 1000 1.0 V ) V S = ±15V S = ±15V 900 mV TA = 25°C ( 800 UT 0.8 NP V) I 700 m O (V/ D T 600 IN 0.6 A RRE 500 E P G F O O 400 0.4 -L R RE 300 PEN RRO O E OP07C 200 0.2 UM IM 100 AX M OP07E 0 0 –75 –50 –25 0 25 50 75 100 125 003100 1k 10k 100k 006TEMPERATURE (°C) MATCHED OR UNMATCHED SOURCE RESISTANCE (Ω) 00316- 00316- Figure 3. Open-Loop Gain vs. Temperature Figure 6. Maximum Error vs. Source Resistance30 1.2 V ) S = ±15V VS = ±15V TA = 25°C, TA = 70°C mV 0°C ≤ TA ≤ 70°C ( 25 1.0 UT UT ) NP I NP V µ O ( 20 N I 0.8 I D T E GE RRE 15 E OLTA 0.6 F THERMAL CHANG SHOCK E T V E RESPONSE R RE UT BAND 10 L 0.4 O OFFS RRO DEVICE IMMERSED E OP07C ABS IN 70°C OIL BATH UM 5 0.2 IM AX M OP07E 0 0 –20 0 20 40 60 80 100 004100 1k 10k 100k 007TIME (Seconds) MATCHED OR UNMATCHED SOURCE RESISTANCE (Ω) 00316- 00316- Figure 4. Offset Voltage Change due to Thermal Shock Figure 7. Maximum Error vs. Source Resistance25 30 V AT |V S = ±15V DIFF| ≤ 1.0V, | IB | ≤ 7nA (OP07C) T A) V A = 25°C n S = ±15V ( T 20 A = 25°C 20 NT UT ) NP V µ N I ( 10 I CURRE E GE 15 AS BI OLTA 0 UT CHANG E T V 10 NP E I OP07C UT L –10 ING O OFFS OP07E RT E ABS 5 NV –20 NI NO 0 –30 0 1 2 3 4 5 005–30 –20 –10 0 10 20 30 008TIME AFTER SUPPLY TURN-ON (Minutes) DIFFERENTIAL INPUT VALUE (V) 00316- 00316- Figure 5. Warm-Up Drift Figure 8. Input Bias Current vs. Differential Input Voltage Rev. G | Page 7 of 16 Document Outline Features Applications General Description Pin Configuration Revision History Specifications OP07E Electrical Characteristics OP07C Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Typical Applications Applications Information Outline Dimensions Ordering Guide
