Datasheet OP07 (Analog Devices) - 7
DescriptionUltralow Offset Voltage Op Amp
Pages / Page17 / 7 — OP07. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. Parameter. Ratings. …
RevisionG
File Format / SizePDF / 254 Kb
OP07. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. Parameter. Ratings. THERMAL RESISTANCE. Table 4. Thermal Resistance. Package Type
OP07 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Ratings THERMAL RESISTANCE Table 4 Thermal Resistance Package Type
link to page 7
OP07 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3.
Stresses above those listed under Absolute Maximum Ratings
Parameter Ratings
may cause permanent damage to the device. This is a stress Supply Voltage (VS) ±22 V rating only; functional operation of the device at these or any Input Voltage1 ±22 V other conditions above those indicated in the operational Differential Input Voltage ±30 V section of this specification is not implied. Exposure to absolute Output Short-Circuit Duration Indefinite maximum rating conditions for extended periods may affect Storage Temperature Range device reliability. S and P Packages −65°C to +125°C Operating Temperature Range
THERMAL RESISTANCE
OP07E 0°C to 70°C θJA is specified for the worst-case conditions, that is, a device OP07C −40°C to +85°C soldered in a circuit board for surface-mount packages. Junction Temperature 150°C
Lead Temperature, Soldering (60 sec) 300°C
Package Type θJA θJC Unit
8-Lead PDIP (P-Suffix) 103 43 °C/W 1 For supply voltages less than ±22 V, the absolute maximum input voltage is equal to the supply voltage. 8-Lead SOIC_N (S-Suffix) 158 43 °C/W
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. G | Page 6 of 16 Document Outline Features Applications General Description Pin Configuration Revision History Specifications OP07E Electrical Characteristics OP07C Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Typical Applications Applications Information Outline Dimensions Ordering Guide
