Datasheet LTC1285, LTC1288 (Analog Devices) - 7
Description3V Micropower Sampling 12-Bit A/D Converters in SO-8 Packages
Pages / Page24 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Minimum Clock Frequency. Digital …
File Format / SizePDF / 355 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Minimum Clock Frequency. Digital Input Logic Threshold. Input Channel Leakage Current
TYPICAL PERFORMANCE CHARACTERISTICS Minimum Clock Frequency Digital Input Logic Threshold Input Channel Leakage Current
LTC1285/LTC1288
W U TYPICAL PERFORMANCE CHARACTERISTICS Minimum Clock Frequency Digital Input Logic Threshold Input Channel Leakage Current for 0.1 LSB Error vs Temperature vs Supply Voltage vs Temperature
120 3.0 1000 VCC = 2.7V TA = 25°C VCC = 2.7V VREF = 2.5V VREF = 2.5V 100 2.5 100 80 2.0 10 60 1.5 1 40 1.0 ON CHANNEL CLOCK FREQUENCY (kHz) LEAKAGE CURRENT (nA) OFF CHANNEL 0.1 20 0.5 2 0 DIGITAL INPUT LOGIC THRESHOLD VOLTAGE (V) 0 0.01 0 10 20 30 40 50 60 70 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 –55 –35 –15 5 25 45 65 85 105 125 TEMPERATURE (°C) SUPPLY VOLTAGE (V) TEMPERATURE (°C) LTC1285/88 • TPC22 LTC1285/88 • TPC23 LTC1285/88 • TPC24
U U U PIN FUNCTIONS LTC1285 LTC1288 VREF (Pin 1):
Reference Input. The reference input defines
CS/SHDN (Pin 1):
Chip Select Input. A logic low on this the span of the A/D converter. input enables the LTC1288. A logic high on this input disables and powers down the LTC1288.
IN+ (Pin 2):
Positive Analog Input.
CH0 (Pin 2):
Analog Input.
IN – (Pin 3):
Negative Analog Input.
CH1 (Pin 3):
Analog Input.
GND (Pin 4):
Analog Ground. GND should be tied directly to an analog ground plane.
GND (Pin 4):
CS/SHDN (Pin 5):
Chip Select Input. A logic low on this input enables the LTC1285. A logic high on this input
DIN (Pin 5):
Digital Data Input. The multiplexer address is disables and powers down the LTC1285. shifted into this input.
DOUT (Pin 6):
Digital Data Output. The A/D conversion
DOUT (Pin 6):
Digital Data Output. The A/D conversion result is shifted out of this output. result is shifted out of this output.
CLK (Pin 7):
Shift Clock. This clock synchronizes the serial
CLK (Pin 7):
Shift Clock. This clock synchronizes the data transfer and determines conversion speed. serial data transfer and determines conversion speed.
VCC (Pin 8):
Power Supply Voltage. This pin provides
VCC/VREF (Pin 8):
Power Supply and Reference Voltage. power to the A/D converter. It must be kept free of noise This pin provides power and defines the span of the A/D and ripple by bypassing directly to the analog ground converter. It must be kept free of noise and ripple by plane. bypassing directly to the analog ground plane. 7
