Datasheet LTC1405 (Analog Devices) - 2
Description12-Bit, 5Msps, Sampling ADC
Pages / Page20 / 2 — ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. 0VDD = VDD (Notes 1, …
File Format / SizePDF / 337 Kb
ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. 0VDD = VDD (Notes 1, 2). CO VERTER CHARACTERISTICS The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO 0VDD = VDD (Notes 1, 2) CO VERTER CHARACTERISTICS The
LTC1405
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO 0VDD = VDD (Notes 1, 2)
TOP VIEW Supply Voltage (V ORDER PART DD) ... 6V +A 1 28 GAIN Negative Supply Voltage (V IN NUMBER SS) .. – 6V –A 2 27 OF Total Supply Voltage (V IN DD to VSS) ... 12V V 3 26 CLK LTC1405CGN CM Analog Input Voltage SENSE 4 25 VSS LTC1405IGN (Note 3) ... (VSS – 0.3V) to (VDD + 0.3V) V 5 24 REF GND Digital Input Voltage GND 6 23 VDD (Note 4) ... (VSS – 0.3V) to (VDD + 0.3V) V 7 22 DD OVDD Digital Output Voltage .. (VSS – 0.3V) to (VDD + 0.3V) GND 8 21 OGND Power Dissipation .. 500mW D11 (MSB) 9 20 D0 Operating Temperature Range D10 10 19 D1 LTC1405C ... 0°C to 70°C D9 11 18 D2 LTC1405I .. – 40°C to 85°C D8 12 17 D3 Storage Temperature Range ... – 65°C to 150°C D7 13 16 D4 Lead Temperature (Soldering, 10 sec).. 300 D6 14 15 D5 °C GN PACKAGE 28-LEAD PLASTIC SSOP TJMAX = 125°C, θJA = 80°C/W Consult factory for parts specified with wider operating temperature ranges.
U CO VERTER CHARACTERISTICS The
C. With Internal 4.096V Reference. Specifications are guaranteed for both dual supply and single supply operation. (Note 5) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution (No Missing Codes) ● 12 Bits Integral Linearity Error (Note 7) ● ±0.35 ±1 LSB Differential Linearity Error ● ±0.25 ±1 LSB Offset Error (Note 8) ±5 12 LSB ● 16 LSB Full-Scale Error ±10 30 LSB Full-Scale Tempco IOUT(REF) = 0 ±15 ppm/°C
U U A ALOG I PUT The
C. Specifications are guaranteed for both dual supply and single supply operation. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Analog Input Range (Note 9) VREF = 4.096V (SENSE = 0V), GAIN = 5V ● ±2.048 V +AIN – (–AIN) VREF = 4.096V (SENSE = 0V), GAIN = 0V ● ±1.024 V VREF = 2.048V (SENSE = VREF), GAIN = 5V ● ±1.024 V VREF = 2.048V (SENSE = VREF), GAIN = 0V ● ±0.512 V External VREF (SENSE = 5V), GAIN = 5V ● ±VREF/2 V External VREF (SENSE = 5V), GAIN = 0V ● ±VREF/4 V IIN Analog Input Leakage Current ● ±10 µA CIN Analog Input Capacitance Between Conversions 12 pF During Conversions 6 pF tACQ Sample-and-Hold Acquisition Time 50 ns 1405fa 2
