Datasheet LTC1594L, LTC1598L (Analog Devices) - 8
Description4- and 8-Channel, 3V Micropower Sampling 12-Bit Serial I/O A/D Converters
Pages / Page24 / 8 — PIN FUNCTIONS. VCC (Pin 15):. VCC (Pin 19):. CH0 (Pin 20):. VREF (Pin …
File Format / SizePDF / 370 Kb
PIN FUNCTIONS. VCC (Pin 15):. VCC (Pin 19):. CH0 (Pin 20):. VREF (Pin 16):. CH1 (Pin 21):. CH2 (Pin 22):. ADCIN (Pin 17):
PIN FUNCTIONS VCC (Pin 15): VCC (Pin 19): CH0 (Pin 20): VREF (Pin 16): CH1 (Pin 21): CH2 (Pin 22): ADCIN (Pin 17):
LTC1594L/LTC1598L
U U U PIN FUNCTIONS VCC (Pin 15):
Power Supply Voltage. This pin provides
VCC (Pin 19):
Power Supply Voltage. This pin should be power to the A/D Converter. It must be bypassed directly tied to Pin 15. to the analog ground plane.
CH0 (Pin 20):
Analog Multiplexer Input.
VREF (Pin 16):
Reference Input. The reference input
CH1 (Pin 21):
Analog Multiplexer Input. defines the span of the ADC.
CH2 (Pin 22):
ADCIN (Pin 17):
ADC Input. This input is the positive analog input to the ADC. Connect this pin to MUXOUT for
CH3 (Pin 23):
Analog Multiplexer Input. normal operation.
CH4 (Pin 24):
MUXOUT (Pin 18):
MUX Output. This pin is the output of the multiplexer. Tie to ADCIN for normal operation.
W BLOCK DIAGRA S LTC1594L LTC1598L
15 5 6 16 18 17 16 15, 19 LTC1594L MUXOUT ADCIN VREF VCC LTC1598L MUXOUT ADCIN VREF VCC 9 CSADC 20 CH0 1 CH0 13 CSMUX 21 CH1 10 2 CH1 CSADC 12-BIT 12 4-CHANNEL CLK + 22 CH2 6 3 CH2 SAMPLING CSMUX 14 MUX ADC D 23 CH3 12-BIT 5, 14 IN 8-CHANNEL 4 CH3 CLK 10 + SAMPLING D – 24 CH4 MUX 7 OUT ADC DIN 7 COM 1 CH5 11 GND – DOUT 2 CH6 12 8 1594L BD NC 3 CH7 13 NC 8 COM GND 1598L BD 4, 9
TEST CIRCUITS Load Circuit for tdDO, tr and tf Voltage Waveforms for DOUT Rise and Fall Times, tr, tf
1.4V VOH DOUT VOL 3k DOUT TEST POINT tr tf 1594L/98L TC02 100pF 1594L/98L TC01 15948lfb 8
