Datasheet LTC1864, LTC1865 (Analog Devices) - 5
DescriptionµPower, 16-Bit, 250ksps 1- and 2-Channel ADCs in MSOP
Pages / Page24 / 5 — DIGITAL AND DC ELECTRICAL CHARACTERISTICS. The. denotes specifi cations …
File Format / SizePDF / 387 Kb
DIGITAL AND DC ELECTRICAL CHARACTERISTICS. The. denotes specifi cations which apply
DIGITAL AND DC ELECTRICAL CHARACTERISTICS The denotes specifi cations which apply
LTC1864/LTC1865
denotes specifi cations which apply over the full operating temperature range, otherwise specifi cations are TA = 25°C. VCC = 5V, VREF = 5V, unless otherwise noted. LTC1864/LTC1865 SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage VCC = 5.25V l 2.4 V VIL Low Level Input Voltage VCC = 4.75V l 0.8 V IIH High Level Input Current VIN = VCC l 2.5 μA IIL Low Level Input Current VIN = 0V l –2.5 μA VOH High Level Output Voltage VCC = 4.75V, IO = 10μA l 4.5 4.74 V VCC = 4.75V, IO = 360μA l 2.4 4.72 V VOL Low Level Output Voltage VCC = 4.75V, IO = 1.6mA ● 0.4 V IOZ Hi-Z Output Leakage CONV = VCC ● ±3 μA ISOURCE Output Source Current VOUT = 0V –25 mA ISINK Output Sink Current VOUT = VCC 20 mA IREF Reference Current (LTC1864 SO-8 and MSOP, CONV = VCC ● 0.001 3 μA LTC1865 MSOP) fSMPL = fSMPL(MAX) ● 0.05 0.1 mA ICC Supply Current CONV = VCC After Conversion ● 0.001 3 μA CONV = VCC After Conversion, H-Grade ● 0.001 5 μA fSMPL = fSMPL(MAX) ● 0.85 1.3 mA PD Power Dissipation fSMPL = fSMPL(MAX) 4.25 mW 18645fb 5
