Datasheet LTC1864L, LTC1865L (Analog Devices) - 2
DescriptionµPower, 3V, 16-Bit, 150ksps 1- and 2-Channel ADCs in MSOP
Pages / Page16 / 2 — ABSOLUTE AXI U RATI GS (Notes 1, 2). PACKAGE/ORDER I FOR ATIO. CO VERTER …
File Format / SizePDF / 366 Kb
ABSOLUTE AXI U RATI GS (Notes 1, 2). PACKAGE/ORDER I FOR ATIO. CO VERTER A D ULTIPLEXER CHARACTERISTICS. The
ABSOLUTE AXI U RATI GS (Notes 1, 2) PACKAGE/ORDER I FOR ATIO CO VERTER A D ULTIPLEXER CHARACTERISTICS The
LTC1864L/LTC1865L
W W W U ABSOLUTE AXI U RATI GS (Notes 1, 2)
Supply Voltage (V Operating Temperature Range CC) ... 7V Ground Voltage Difference LTC1864LC/LTC1865LC/ AGND, DGND LTC1865L MSOP Package ... ±0.3V LTC1864LAC/LTC1865LAC .. 0°C to 70°C Analog Input ... (GND – 0.3V) to (V LTC1864LI/LTC1865LI/ CC + 0.3V) Digital Input .. (GND – 0.3V) to 7V LTC1864LAI/LTC1865LAI ... – 40°C to 85°C Digital Output .. (GND – 0.3V) to (V Storage Temperature Range ... – 65 CC + 0.3V) °C to 150°C Power Dissipation .. 400mW Lead Temperature (Soldering, 10 sec)... 300°C
U W U PACKAGE/ORDER I FOR ATIO
ORDER PART ORDER PART NUMBER NUMBER TOP VIEW TOP VIEW LTC1864LCMS8 CONV 1 10 V LTC1865LCMS V 1 REF 8 VCC REF IN+ 2 7 SCK LTC1864LIMS8 CH0 2 9 VCC LTC1865LIMS IN¯ 3 6 SDO CH1 3 8 SCK GND 4 5 CONV LTC1864LACMS8 AGND 4 7 SDO LTC1865LACMS DGND 5 6 SDI MS8 PACKAGE LTC1864LAIMS8 LTC1865LAIMS 8-LEAD PLASTIC MSOP MS PACKAGE 10-LEAD PLASTIC MSOP T MS8 PART MARKING MS PART MARKING JMAX = 150°C, θJA = 210°C/W TJMAX = 150°C, θJA = 210°C/W LTC7 LTJ4 ORDER PART ORDER PART TOP VIEW NUMBER TOP VIEW NUMBER V 1 8 REF VCC LTC1864LCS8 CONV 1 8 VCC LTC1865LCS8 IN+ 2 7 SCK LTC1864LIS8 CH0 2 7 SCK LTC1865LIS8 IN– 3 6 SDO LTC1864LACS8 CH1 3 6 SDO LTC1865LACS8 GND 4 5 CONV LTC1864LAIS8 GND 4 5 SDI LTC1865LAIS8 S8 PACKAGE S8 PACKAGE 8-LEAD PLASTIC SO S8 PART MARKING 8-LEAD PLASTIC SO S8 PART MARKING TJMAX = 150°C, θJA = 175°C/W 1864L 1864LA TJMAX = 150°C, θJA = 175°C/W 1865L 1865LA 1864LI 864LAI 1865LI 865LAI Consult LTC Marketing for parts specified with wider operating temperature ranges.
U U W CO VERTER A D ULTIPLEXER CHARACTERISTICS The
denotes specifications which apply over the full operating temperature range, otherwise specifications are TA = 25
C. VCC = 2.7V, VREF = 2.5V, fSCK = fSCK(MAX) as defined in Recommended Operating Conditions, unless otherwise noted.
LTC1864L/LTC1865L LTC1864LA/LTC1865LA PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Resolution ● 16 16 Bits No Missing Codes Resolution ● 14 15 Bits INL (Note 3) ● ±8 ±6 LSB Transition Noise 2 2 LSBRMS Gain Error ● ±20 ±20 mV sn18645L 18645Lfs 2
