Datasheet LTC1864L, LTC1865L (Analog Devices) - 7
DescriptionµPower, 3V, 16-Bit, 150ksps 1- and 2-Channel ADCs in MSOP
Pages / Page16 / 7 — PI FU CTIO S. LTC1864L. VREF (Pin 1):. SDO (Pin 6):. IN+, IN– (Pins 2, …
File Format / SizePDF / 366 Kb
PI FU CTIO S. LTC1864L. VREF (Pin 1):. SDO (Pin 6):. IN+, IN– (Pins 2, 3):. SCK (Pin 7):. GND (Pin 4):. VCC (Pin 8):. CONV (Pin 5):
PI FU CTIO S LTC1864L VREF (Pin 1): SDO (Pin 6): IN+, IN– (Pins 2, 3): SCK (Pin 7): GND (Pin 4): VCC (Pin 8): CONV (Pin 5):
LTC1864L/LTC1865L
U U U PI FU CTIO S LTC1864L VREF (Pin 1):
Reference Input. The reference input defines down. A logic low on this input enables the SDO pin, the span of the A/D converter and must be kept free of allowing the data to be shifted out. noise with respect to GND.
SDO (Pin 6):
Digital Data Output. The A/D conversion
Analog Inputs. These inputs must be result is shifted out of this pin. free of noise with respect to GND.
SCK (Pin 7):
Shift Clock Input. This clock synchronizes the
GND (Pin 4):
Analog Ground. GND should be tied directly serial data transfer. to an analog ground plane.
VCC (Pin 8):
Positive Supply. This supply must be kept
CONV (Pin 5):
Convert Input. A logic high on this input free of noise and ripple by bypassing directly to the starts the A/D conversion process. If the CONV input is left analog ground plane. high after the A/D conversion is finished, the part powers
LTC1865L (MSOP Package) CONV (Pin 1):
SDO (Pin 7):
Digital Data Output. The A/D conversion starts the A/D conversion process. If the CONV input is left result is shifted out of this output. high after the A/D conversion is finished, the part powers
SCK (Pin 8):
Shift Clock Input. This clock synchronizes the down. A logic low on this input enables the SDO pin, serial data transfer. allowing the data to be shifted out.
V CH0, CH1 (Pins 2, 3):
CC (Pin 9):
Positive Supply. This supply must be kept free of noise and ripple by bypassing directly to the be free of noise with respect to AGND. analog ground plane.
AGND (Pin 4):
Analog Ground. AGND should be tied
V
directly to an analog ground plane.
REF (Pin 10):
Reference Input. The reference input de- fines the span of the A/D converter and must be kept free
DGND (Pin 5):
Digital Ground. DGND should be tied of noise with respect to AGND. directly to an analog ground plane.
SDI (Pin 6):
Digital Data Input. The A/D configuration word is shifted into this input.
LTC1865L (SO-8 Package) CONV (Pin 1):
SDI (Pin 5):
Digital Data Input. The A/D configuration starts the A/D conversion process. If the CONV input is left word is shifted into this input. high after the A/D conversion is finished, the part powers
SDO (Pin 6):
Digital Data Output. The A/D conversion down. A logic low on this input enables the SDO pin, result is shifted out of this output. allowing the data to be shifted out.
SCK (Pin 7):
Analog Inputs. These inputs must serial data transfer. be free of noise with respect to GND.
V GND (Pin 4):
CC (Pin 8):
Positive Supply. This supply must be kept free of noise and ripple by bypassing directly to the to an analog ground plane. analog ground plane. VREF is tied internally to this pin. sn18645L 18645Lfs 7
