Datasheet LTC2145-14, LTC2144-14, LTC2143-14 (Analog Devices) - 7
Description14-Bit, 125Msps Low Power Dual ADCs
Pages / Page38 / 7 — POWER REQUIREMENTS. The. denotes the specifications which apply over the …
File Format / SizePDF / 668 Kb
POWER REQUIREMENTS. The. denotes the specifications which apply over the full operating temperature
POWER REQUIREMENTS The denotes the specifications which apply over the full operating temperature
LTC2145-14/ LTC2144-14/LTC2143-14
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 9) LTC2145-14 LTC2144-14 LTC2143-14 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS CMOS Output Modes: Full Data Rate and Double Data Rate
VDD Analog Supply Voltage (Note 10) l 1.7 1.8 1.9 1.7 1.8 1.9 1.7 1.8 1.9 V OVDD Output Supply Voltage (Note 10) l 1.1 1.8 1.9 1.1 1.8 1.9 1.1 1.8 1.9 V IVDD Analog Supply Current DC Input l 105.2 116 82.8 92 62.8 70 mA Sine Wave Input 105.9 83.3 63.2 mA IOVDD Digital Supply Current Sine Wave Input, OVDD = 1.2V 8.5 7.1 5.4 mA PDISS Power Dissipation DC Input l 189 209 149 166 113 126 mW Sine Wave Input, OVDD = 1.2V 201 159 120 mW
LVDS Output Mode
VDD Analog Supply Voltage (Note 10) l 1.7 1.8 1.9 1.7 1.8 1.9 1.7 1.8 1.9 V OVDD Output Supply Voltage (Note 10) l 1.7 1.8 1.9 1.7 1.8 1.9 1.7 1.8 1.9 V IVDD Analog Supply Current Sine Input, 1.75mA Mode 107.3 84.7 64.6 mA Sine Input, 3.5mA Mode l 108.7 123 86.1 97 66.1 75 mA IOVDD Digital Supply Current Sine Input, 1.75mA Mode 35.1 34.8 34.5 mA (0VDD = 1.8V) Sine Input, 3.5mA Mode l 66.3 77 66 76 65.7 76 mA PDISS Power Dissipation Sine Input, 1.75mA Mode 256 215 178 mW Sine Input, 3.5mA Mode l 315 360 274 312 237 272 mW
All Output Modes
PSLEEP Sleep Mode Power 1 1 1 mW PNAP Nap Mode Power 16 16 16 mW PDIFFCLK Power Increase with Differential Encode Mode Enabled 20 20 20 mW (No increase for Nap or Sleep Modes)
TIMING CHARACTERISTICS The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) LTC2145-14 LTC2144-14 LTC2143-14 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
fS Sampling Frequency (Note 10) l 1 125 1 105 1 80 MHz tL ENC Low Time (Note 8) Duty Cycle Stabilizer Off l 3.8 4 500 4.52 4.76 500 5.93 6.25 500 ns Duty Cycle Stabilizer On l 2 4 500 2 4.76 500 2 6.25 500 ns tH ENC High Time (Note 8) Duty Cycle Stabilizer Off l 3.8 4 500 4.52 4.76 500 5.93 6.25 500 ns Duty Cycle Stabilizer On l 2 4 500 2 4.76 500 2 6.25 500 ns tAP Sample-and-Hold 0 0 0 ns Acquisition Delay Time
SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Digital Data Outputs (CMOS Modes: Full Data Rate and Double Data Rate)
tD ENC to Data Delay CL = 5pF (Note 8) l 1.1 1.7 3.1 ns tC ENC to CLKOUT Delay CL = 5pF (Note 8) l 1 1.4 2.6 ns tSKEW DATA to CLKOUT Skew tD – tC (Note 8) l 0 0.3 0.6 ns Pipeline Latency Full Data Rate Mode 6 Cycles Double Data Rate Mode 6.5 Cycles 21454314fa 7
